Old 6th May 2007, 05:07 PM   #531
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Are the drawing's / pcb-layout, from post#575 corrected, so that Q2 sits right ?, following the toplayer ?
Jesper
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Old 6th May 2007, 05:10 PM   #532
veteran is offline veteran  Poland
veteran's Avatar
Now all drawing presenting R0 version are correct because all of them point the same links on my www.
Simple audio solutions
blog.unisonus.com
Old 7th May 2007, 05:17 AM   #533
Darry is offline Darry  France
Veteran,
Why do you connect the diode D3 to +23V and D4 to -23V ?
In the schematic of the version R0 of M. Nelson Pass, D3 is connected to the drain of Q1, to R6 and P2. D4 is connected to the drain of Q2, to R7 and R5.
Darry
Old 7th May 2007, 01:16 PM   #534
doggy is offline doggy  Canada
doggy's Avatar
Default RA
veteran
What is the purpose for the resistor "ra,rb"-10r and the 100nf ca,cb cap.?
thank-you
Old 7th May 2007, 06:34 PM   #535
veteran's Avatar
Originally posted by Darry
Veteran,
Darry
I'm basing on R0 schematic from 4/17/2007. Those diodes are directly connected to (-) and (+) rails.
Additional resistors if you want to have some small separation from output stage . Take a look at my schematic and if you don't want to use them - place jumpers.
blog.unisonus.com
Old 7th May 2007, 07:02 PM   #536
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
A correction to initial schematic has been done here: http://www.diyaudio.com/forums/showt...00#post1185900
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th May 2007, 07:05 PM   #537
Veteran,
Sorry but on R0 schematic from 4/17/2007 enclosed, those diodes are not directly connected to (-) and (+) rails.
Darry
Old 7th May 2007, 07:34 PM   #538
Sorry Veteran, you have also reason.
I had the enclosed schematic R0, also from 4/17/2007 with different connection for D3 and D4 diodes.
Maybe that Nelson will say us what is the good schematic !!!
There is also a little difference between the schematic of the service manual and the R0 version.
On the service manual, the input is on R1 and for the R0 version, the input is between R1 and R2.
How to connect input ?
Old 7th May 2007, 11:29 PM   #539
The one and only
Nelson Pass's Avatar
While both these schematics work fine, neither is the correct
version.
Peter is correct:
navigate to www.passlabs.com/np and download the f4r0 pdf.
You will note that D3 and 4 are connected slightly differently.
Old 7th May 2007, 11:56 PM   #540
Perhaps this is too off the subject, but...
Since the biggest hassle is the enclosure,
and the biggest expense is the PS,
and since the F4 is an odd duck (a really great odd duck),
I'm thinking of building in another two channels (of a more conventional)
amplifier, utilizing the same case and power supply.
What, in your opinions, should that other amp be?
I'm leaning towards a Peter Daniel Chip amp.
Any ideas...
They wouldn't necessarily be used together, but perhaps the F4 as full range and other driving supertweeter or sub.
-Thanks - Marsupialx
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
raneypdx
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.13435 seconds (73.41% PHP - 26.59% MySQL) with 11 queries
