F4 power amplifier
F4 power amplifier
Old 2nd May 2007, 07:24 PM   #521
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
The most interesting discussion about a preamp for the F4 can be found here:
http://www.diyaudio.com/forums/showt...0&pagenumber=1
Hugo
Old 2nd May 2007, 08:48 PM   #522
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Hugo
Thank u for that !!! the speed of this thread was almost quicker then the speed of light !
Anyone have an update about his F4 ? no ok I'll give it a try
Today i received my secondhand heatsinks, the sk56 from fischer at about 200mm height they will do 0,3 C/W. I also using these on my aleph 5's. I planning to build first one stereo F4 and later on i will build an other one so I can use them balanced.
I'm currently searching for a nice toroid 300VA or something like that.
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 2nd May 2007, 09:00 PM   #523
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
Originally posted by analogair
I know they should be rated as having a sencitivity at 96dB/1m/ 8w
93db/1m/4W
90db/1m/2W
87db/1m/1W
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd May 2007, 09:04 PM   #524
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
F4 power amplifier
Jaac TheMaster-
Nice bookends!
Old 2nd May 2007, 09:07 PM   #525
Netlist's Avatar
Blame Zen Mod.
I have split everything past post #530. Credit for spotting goes to cviller. If anything needs to be put back into this thread, just mail me the post numbers and I'll comply.
/Hugo
Old 2nd May 2007, 09:13 PM   #526
Jaac's Avatar
Originally posted by BrianDonegan
Jaac TheMaster-
Nice bookends!
thanks !! A welder, some iron voila
Old 2nd May 2007, 10:18 PM   #527
analogair is offline analogair  Denmark
analogair's Avatar
.... a pair of B&W Matrix 801 Series 2
I somehow am pretty sure that the are harder to drive than that, so if someone have some real life specs...
I have been reading a lot of articles about my speakers, and some writes about them having lower sencitivity than the mentioned 96dB/1m/8w.....Anybody ?
Originally posted by Zen Mod
93db/1m/4W
90db/1m/2W
87db/1m/1W
84db/1m/ .50W
81db/1m/ .25W
78db/1m/ .125W
I know the math, but thanks anyway Zen Mod
Sorry for the off topic guy's
air is analog
Old 6th May 2007, 10:07 AM   #528
veteran is offline veteran  Poland
veteran's Avatar
Thanks to Peter Daniel I corrected one mistake on my PCB for this amplifier - Q2 was inverted. Now everything is OK. For those who made this PCB in previous version - all you need to do is invert this transistor.
http://www.unisonus.com/pdf/f4_r0_pcb.pdf
http://www.unisonus.com/pdf/f4_r0_top_mirror.pdf
http://www.unisonus.com/pdf/f4_r0_sch.pdf
Simple audio solutions
blog.unisonus.com
Old 6th May 2007, 04:31 PM   #529
twitchie is offline twitchie  Canada
What effect would having Q2 inverted have on the amp? Would that mean it was not working as a push-pull amp and (if I understand correctly).
Would there be any damaged components I should check for (aside from Q2).
I have built Veteran's layout, but since my speakers are all very inefficient, I haven't put many hours into running it so far
Thanks,
Stephen
Old 6th May 2007, 05:02 PM   #530
veteran's Avatar
Those are P channel FET transistors. In low current application there shouldn't be no difference how you connect them - this is result of production technology which is not perfect
blog.unisonus.com
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
