#41 | |
Formerly "jh6you". R.I.P.
Thanks, I will go with mismatchd stones as I have had experience of it with Zen V5. I will re-fill F1 having a bit higher rail voltages. I would try to adjust R values, if necessary. I might be able to manage this within few days when I get jfets, not using PCBs, but applying P2P as usual. ~ ^^ |
#42 |
Papa and Jon,
I am curious, since you are the only two who have listened to all the First Watt amps with Lowthers, as to which amp you personally like best ? Thanks. James |
#43 | |
Mr. Pass, may I know why you prefer to use TL431 in place of the usual Vgs multiplier, which is more common in the push-pull stage with the added benefit of temperature feedback? How does F4 overcome the temperature instability? I've just completed F2 and SL10. It just sound marvelous driving my Coral Flat 8A and now I'm addicted to build the F4. Thanks a lot Mr. Pass. |
#44 | |
The F1 is super clean and dynamic. If your source is lean, your music will be lean. If your source is rich, your music will be rich. It is the real truth machine, with nothing taken out and nothing added. Ruthlessly revealing. The F2 adds some 2nd harmonic to this. On lean source material this sounds better than the F1. It is putting a little color in your music, and on dry material it is a pleasant addition. Some like that additional color, some do not. Your choice. The F3 sounds has a very light touch of sweetness. Sounds more like a great tube amp than any solid state amp I have heard, except that it has the same basic tonal characteristics from highs to lows - something most tube amps dream about. The F4 sounds like a cross between the F1 and the F3. Cleaner than the F2, a touch of sweetness, but the truth is still front and center. I have not heard this amp in my system (yet), so my thoughts about this may change. It is a very exciting product. Nelson, with his greater experience, may be better able to describe all of these amps. But as to which is best? That is like saying vanilla is better than strawberry - it is a matter of what you enjoy. All of these bring something different to the table. Not sure if that helps, but it is the best I can do.
Jon Ver Halen Lowther-America |
#45 |
Jon, nice round up for the lot, I appreciate...Thanks
#46 | |
Not having input Jfets at the moment, I was thinging about ways to make a simple buffer with irf610/irf9610 or similar, but..than it may loose a bit of sweetness. Using matched ouput devices should make it a bit more "clear" while unmatched provide more"romantic" sound? Have I gone too far? |
#47 | |
Papa talk about mismatching between 240 and 9240 seems that everybody else talk about matching (or not ) between devices ; this is -still-preferable............
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#48 |
Great thanks to mr.Pass for shearing one of his ideas with us!
As I can see, the bias current trough the resistors network for the mosfets gates is about 1.4mA. Some wold say that`s funny! You have to drive the gate`s capacitances (3*IRFP240). How do you expain this mr.Pass? Cheers! |
#49 | |
AC or DC current ,when you think about gates? ![]() anyway-look what's common there.........source or drain.....
#50 | |
If that tube will run well at that voltage, then by all means give it a try. Grey |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| raneypdx |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.12591 seconds (59.52% PHP - 40.48% MySQL) with 11 queries |
