#481 | |
welcome to the club
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#482 |
At 91.5db/w it seems I have to repeat myself, something isn't right if 25W can't deliver the goods! Most likely as somebody suggested, the pre isn't up to the job.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#483 |
Actually the MF A1 has specs that says 2 x 20W into 8 ohm Class A, but im sertain they only go about 8-10W in Class A...
The Audiovector 4 have been put away in my basement and have been replaced with a pair of B&W Matrix 801 Series 2 I know they should be rated as having a sencitivity at 96dB/1m/ 8w I somehow am pretty sure that the are harder to drive than that, so if someone have some real life specs on my new used babys. But i can actually turn the knob almost to 11 o'clock before the sound turns muddy and uncomfortable. Just before that it is actually pretty loud, but not as loud as i would like it to be for some sorts of music (read.. Roger Waters, Dire Straits, Thin Lizzy, Midnight Oil, Queen...etc...)
air is analog |
#484 | |
The soundpressure, is louder now, maybe 3/5 maybe even a little more !!! Of what the speaker's usually are playing when driving near to the max, with my leachamp. So i guess Magura is right when telling me, that the preamp is the problem.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#485 | |
correction: "So i guess steen is right when telling me, that the preamp is the problem ![]() anyway-change the spks
#486 |
I am attempting to build the F4 point to point. Waiting for parts from tech diy, the rest I sourced from digikey. Has anyone compared the A30 to the F4, and what would the differences be? I would assume less gain with the F4; and perhaps more transparency? With my fostex fe108ez-mcm 8"combo horn I have lots of power with the A30 and very enjoyable.
#487 |
Steenoe, you probably skipped my post #456 on this thread (page 46) and my offer. That is still valid, if you want to try.
#488 | |
I was wondering about this note, from the f4 power amp papers (not rev0).
Jesper
#489 | |
You'll find the answer here and a few posts later when steen finishes his amp. http://www.diyaudio.com/forums/showt...23#post1169323 |
#490 |
Actually i was looking at youre post,but it doesent come clear to me, how much current / voltage each mosfet must swallow
I am just preparing a setup for matching mosfets... Se this LINK So i would just like to know the voltage / current, for correct matching. (And to test the heatdissapation too) Jesper
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| raneypdx |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.13110 seconds (77.45% PHP - 22.55% MySQL) with 11 queries |
