F4 power amplifier
F4 power amplifier
Old 12th January 2018, 02:59 PM   #4321
6L6 is offline 6L6  United States
6L6's Avatar
F4 power amplifier
BA-3 output stage holds the bias circuit a little differently, look at C1 and the diodes and where the gian stage drives it.
The Output buffers you ask about are all essentially identical - they are IRF240/9240 push pull followers. Followers don't impart much signature at all to the circuit. Which means they will all sound very similar, and that sound will pretty much be like whatever you drive them with.
Old 12th January 2018, 03:05 PM   #4322
marconi118 is offline marconi118  Germany
Refering to the BA PP output and gain stage I don't understand your explanation about C1
Old 12th January 2018, 03:36 PM   #4323
wdecho is offline wdecho  United States
F4 power amplifier
It seems the same as F4 and M2Attachment 656383
Attachment 656384
From the Firstwatt BA-3 article.
http://www.firstwatt.com/pdf/art_ba_3.pdf
Coming off the Drain of Q1 is the loading network of R6, C1 and P1, and there is a
comparable network of R7, C2, and P2 attached to the Drain of Q2. R6 clearly sets the AC
load for Q1, but the DC requirements to bias up Mosfet Q3 are higher than that, so P1 in
parallel with C1 provides a higher resistance value below about 0.5 Hz, and gives the
approximately 3 volt DC drop required to bias the Mosfets
Old 12th January 2018, 03:43 PM   #4324
I am referring to the BA output stage vs the F4 and M2
The BA-3 gain stage is cap coupled to the output stage has nothing to do with bias and ground reference
Old 12th January 2018, 04:07 PM   #4325
any substitute for input Jfets? as they are only buffer, some lower transconductance jfets could still give good performance
Old 12th January 2018, 04:13 PM   #4326
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
why asking same thing in more than one thread ?
somebody will answer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th January 2018, 04:15 PM   #4327
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
But... Can it drive a F4?
Old 12th January 2018, 05:48 PM   #4328
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F4 power amplifier
You can remove them entirely if your source has a reasonably low
output impedance.
Old 16th January 2018, 03:48 PM   #4329
my source has 10K output impedance
Old 16th January 2018, 05:46 PM   #4330
The one and only
F4 power amplifier
Then you need the Jfets. The raw F4 output stage is OK up to about 1K source.
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
