F4 power amplifier
F4 power amplifier
Old 7th November 2017, 12:34 AM   #4291
soldersmoker is offline soldersmoker  United States
I had a pair of Wild Burro Betsys a few years ago, so I'm familiar with the OB magic those were able to pull off (even though they aren't the best drivers ever). Again, thanks for the great suggestion!
Old 19th November 2017, 04:31 PM   #4292
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
F4 power amplifier
Just wanted to give a heads up that Hugh Dean and I have developed a nice preamp with 40v p-p output with low distortion and SE Class A harmonic profile. It's been tested in prototype stage already. JPS64 will be releasing Gerbers for easy construction soon. It's a 5 transistor affair, very simple but clean output. Sound is superb and can drive any amp to clip without adding hardly any distortion.
AKSA's Lender Preamp with 40Vpp Output
Incidentally, we are running sims of a boosted 100v rail version that can swing 90vpp into 10kohms and looks like this:
AKSA's Lender Preamp with 40Vpp Output-aksa-lender-preamp-hv-v2-1-90vpp-10kohms-fft-jpg
Here is the schematic of the souped up 90vpp version:
AKSA's Lender Preamp with 40Vpp Output-aksa-lender-preamp-hv-v2-1-schematic-jpg
The JPS64 design of the 40vpp version has SMT daughter boards on a main board with selector switches and PSU and looks like this:
Here is a closeup of the actual preamp daughter board:
For comparison, here my hand-made SMT prototype that I am listening too now:
Measured FFT for 20vpp into 7kohm load:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th December 2017, 11:05 AM   #4293
wdecho is offline wdecho  United States
F4 power amplifier
Originally Posted by Zen Mod View Post
1. yes
2. build it exactly as shown on attached pic ; you can omit R2 - it's there for cap bleeding purpose and not needed if entire shebang used as permanent OS
I decided to convert my F4 to the crippled F4 using Zen's schematic and installing a BA-3 pre board inside the case. It has made the F4 more in line with the BA-2 with BA-3 driver and made the amplifier much more versatile. Not hard to do and I have a set of spare j-fets for another project being that I already had the stuffed BA-3 board.
Old 18th December 2017, 11:08 AM   #4294
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
I decided to make LuDEF amp , as soon I have time
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th December 2017, 11:20 AM   #4295
F4 power amplifier
I'm in.
Old 18th December 2017, 06:40 PM   #4296
Zen Mod's Avatar
F4 power amplifier
you can be faster than Mighty Moi , if you wish
Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
fit M2 FE on it , et voila!
Old 2nd January 2018, 07:40 AM   #4297
marconi118 is online now marconi118  Germany
Is it possible to build an f4 with only a pair of verticals and omit source resistors?
Old 2nd January 2018, 08:04 AM   #4298
lhquam is offline lhquam  United States
That would be fine if the transconductance of the verticals was high enough.
Old 2nd January 2018, 08:06 AM   #4299
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Yes I did it
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 2nd January 2018, 10:22 AM   #4300
And how it sounds?
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
