F4 power amplifier
F4 power amplifier
Old 29th June 2014, 07:32 PM   #4101
albertNL is offline albertNL  Australia
F4 power amplifier
Originally Posted by Nelson Pass View Post
If you are using GR Jfets, you can get a little more bias on them by reducing
R3 and R4 to 1 ohm instead of 10. Actually, you can just short R3 and R4,
but 1 ohm lets you sense the current if you want.
Thanks Nelson, I will try to get this done next week. Hope to hear some magic when it is done. Albert
Old 29th June 2014, 08:27 PM   #4102
Triodethom is offline Triodethom  United States
Triodethom's Avatar
So 22.1 ohm originally used is for idss in the 9 to 10 ma range is that correct ?
Old 30th July 2014, 03:19 PM   #4103
Marra is offline Marra  United Kingdom
F4 power amplifier
Would a preamp with 12db of gain give enough output from the F4 to drive speakers of 90db efficiency?
Old 30th July 2014, 03:39 PM   #4104
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
2Vrms will give 8Vrms
that's 8W/8R
99db
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th July 2014, 04:27 PM   #4105
6L6 is offline 6L6  United States
6L6's Avatar
F4 power amplifier
If you are not a devotee of Black Sabbath at continuous concert levels, that's more than enough.
Old 30th July 2014, 04:41 PM   #4106
F4 power amplifier
Thanks guys.
I think that I will have to try one of these.My valve pre sounds really good with the Aleph J but the volume pot barely gets more than a few clicks to reach loud.
Old 30th July 2014, 04:44 PM   #4107
F4 power amplifier
Hi guys,
It all took a bit longer than I had hoped, but I have some more information.
As I explained I have two identical F4's. One is at my home, the other back at my friend who built them for me.
I was pretty sure that the JFets used were GR grade so I followed up on Nelson's advice and did some quick and dirty soldering: I added 1R2 resistors parallel to the original 10R (R3 & R4) to give about 1R overall but this has not helped the sound.
I only just re-read a lot of posts in this thread and had not realised I should have measured the voltage drop across R3/R4.
My friend just emailed that he has checked the JFets in the second F4 and has confirmed the grade is GR. I have asked him to measure the voltage drop across R3 and R4 (with original 10R in place) and hope to get an answer in the next day or so.
In order to decide what I should do, I have a few questions:
1. What can I expect with GR grade JFets?
2. Can the GR supply the current the circuit requires?
3. Is the sound going to be as good as with BL (i.e. is it just a matter of finding the right resistance value)?
4. Or is the BL better suited and would replacing the JFets be the best option?
I am afraid I have a similar problem coming up, my F5.
When I ordered kits from tech-diy for the 2 F4's I included an F5 kit. My friend is still working on the F5 but has checked and confirms the F5 kit also contained GR grade JFets.
Same questions as above for the F5.
5. Should I try to get it to work with the GR's or is replacement with BL the best option?
Your help is appreciated.
Thanks,
Albert
Old 30th July 2014, 04:50 PM   #4108
6L6's Avatar
F4 power amplifier
F4 - with the change in the source resistors the GR should work fine. I would suspect something else, likely bias. Is the F4 to proper bias? Also, what preamp are you driving the F4 with?
F5 - GR are no problem, (My F5 uses them) just increase resistance in series with the bias pots until they bias properly.
Old 30th July 2014, 05:14 PM   #4109
F4 power amplifier
My friend biased the F4's to 250mv. DC offset is close to 0. The sinks get hot but not too hot.
I don't think the preamp is the problem.
In my study I listened to one of the F4's using an old Yamaha CX-1000 preamp (I hope to replace it with a DIY Aleph P1.7 some day).
My brother tried the other F4 using a Metaxas preamp (using >95dB Lowther based speakers).
When I compare the sound of the F4 to a diy Aleph J (same source, same Yamaha CX-1000, same old speakers) it sounds boxed-in, no midrange and harsh. Plenty of bass but even that does not sound right.
My brother found that the soundstage collapsed (compared to the Metaxas power amps he normally uses): He could hear speakers rather than a soundstage. Mid-fi at best. Not at all what it should sound like.
Old 30th July 2014, 06:59 PM   #4110
Zen Mod's Avatar
F4 power amplifier
whatever you do , F4 will transfer character of preceding stage , adding 2% of it's own
so - same preamp is idling with normal gain amps , while screaming full throttle , while feeding F4 ; hardly same conditions
take proper and muscular (swing wise) preamp stage* , then you'll hear that you can't really hear F4 itself
*BA3 , Impasse , , few else
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
