Old 7th March 2007, 10:06 AM   #31
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by juma
In that case the input JFET pair could be left out of the circuit.
Without the JFET input it would look like a PP output stage for a hybrid tube-MOSFET power amp, such as the one on the picture.
I've tested that output stage, connected to a pre-amp before the tube front end was hooked up.
Adding a buffer and then running the circuit balanced is a really cool idea. Wish i thought of that, as usual.
Looks like Sponge Bob has killed another thread.
Old 7th March 2007, 10:32 AM   #32
wuffwaff's Avatar
Originally posted by flg
There is something a little confusing here though Grey The old Class A peak output current rule... That you can get double the queicent current out. Nelson gets more than that???
Dosen't this thing idle at 1.5A or so??? Gets 20V peak to the load??? O.K. thats good for 25Watts out...
But when you drive a 4 ohm load... If you can drive 20Volts out, thats 50 watts like he says but thats 5A pk??? Well beyond the double the idle current addage of old. Does this thing do Class AB for that power level???
Did I miss something???
Yes,
AB it is.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 7th March 2007, 12:15 PM   #33
MRupp is offline MRupp  Germany
MRupp's Avatar
While the rails are similar, I'm not a big fan of running tubes at reduced voltages.
Yes, but in this case you have a tube designed for low voltage, max. anode voltage for ECC86 is 30V and running them at say 12 V is within their normal operating range. It might not be the best tube for other reasons though ....
Martin Rupp
Old 7th March 2007, 05:23 PM   #34
steenoe is offline steenoe  Denmark
steenoe's Avatar
I have a nearly infinite capacity for 'woo.'
Me too I can be woo-woo'ed all day with no ill effect, at all. I think it was Metalman who said the "woo-woo- button" thing
F4; another genious act of Mr. Pass. Did anyone build this thing yet?
Being a study in simplicity, it shouldn't take long to weld one together
Steen
Old 7th March 2007, 07:39 PM   #35
The one and only
Nelson Pass's Avatar
You mean that bootstrapped TL refrence bissiness???
There's a bootstrap in the amplifier?
Originally posted by wuffwaff
AB it is.
The calculation goes 1.59A * 2 = 3.18A peak
3.18 * 3.18 *8 = 80 watts peak Class A into 8 ohms
and 40 watts peak into 4 ohms
Old 7th March 2007, 07:41 PM   #36
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Steen
who can be faster than you in this?
hehe
you even have pcb pdfs.........
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 7th March 2007, 07:56 PM   #37
steenoe's Avatar
And also even have matched IRFP9240's in the drawer, together with a bunch of Toshiba's
Steen
Old 7th March 2007, 08:07 PM   #38
Zen Mod's Avatar
Steen
hehe..........you don't have N and P jfet in one case ..........
Old 7th March 2007, 08:07 PM   #39
The one and only
Commenting on the particular mis-match of the complementary
types, notice that the distortion is primarily second harmonic
on the amplifier and that the distortion vs power curve looks
just like a classic single-ended amp.
This imparts a particular sonic signature different from the
usual push-pull arrangement where the character is 3rd harmonic.
Old 7th March 2007, 08:12 PM   #40
steenoe's Avatar
Mr. Pass, that was just, what I needed to hear (read!)
Steen
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.12271 seconds (70.33% PHP - 29.67% MySQL) with 11 queries
