F4 power amplifier
F4 power amplifier
Old 29th July 2013, 08:28 PM   #3651
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Originally Posted by valvesound View Post
So does this mean that there is no effect of the electrolytics on the sound?
Which ones ? The f4 is a current buffer so the cap should have less effect because of no voltage gain . That is at least my take on it .
Old 29th July 2013, 08:34 PM   #3652
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I would listen first. If you like it, then you have the possibility of tweaking the sound with cap choice. If you don't like it, you saved that little bit'o money for the next build.
...Shape the sound , Man!
Old 30th July 2013, 07:42 AM   #3653
valvesound is offline valvesound  South Africa
valvesound's Avatar
For C1 and C2.....I'll try it first with the standard 220u Elna silmic's and then maybe try 22u polyprops as they do show on sim to be sufficient. Maybe someone has tried that and can comment on it.
Old 30th July 2013, 09:02 PM   #3654
generg is offline generg  Germany
generg's Avatar
F4 power amplifier
The values of the caps are so high to minimize the turn on plopp.....of course 22uF are enough for audio purposes but I suppose not to avoid the plopp.....
The simulation can't hear the Plopp!
and the First Wtt is......a really First Class PSS Idea
Old 30th July 2013, 09:07 PM   #3655
generg's Avatar
F4 power amplifier
You can try the solution Nelson used in BA-2
10uF of a good film cap or Elna 10uF/16V from the inputstage and 1000uF in the upper branch to avoid the Plopp!
Old 31st July 2013, 06:21 AM   #3656
valvesound's Avatar
thanks for the good explanation and suggestion generg
Old 2nd August 2013, 06:33 AM   #3657
slr 5000 is offline slr 5000  Australia
hi all
can sony 2sk82/2sj28 or semisouth r100 be adapted to work in this design
I,m looking for something they will drop into with minimal fuss and make 25 to 50w
Sheafer
Old 2nd August 2013, 07:52 AM   #3658
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
2sk82/2sj28 - yes ( more than few amps are floating around , made with them as follower stage)
SSR100 - you need counterpart for it ...... and there is none
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd August 2013, 07:56 AM   #3659
hi Zen
that is what I was hoping to hear
any chance of one of your famous sketches ? I am thinking about one pair per channel
rgds Sheafer
Old 2nd August 2013, 08:19 AM   #3660
Zen Mod's Avatar
F4 power amplifier
frankly - in source follower iteration , I can't see any value of using old , made of preputium , parts ;
make F4 lookalike and save Sony parts for something where you can more exploit their rare transfer characteristic
say something as F6 complementary ....... there you can find one sketch of Mighty ZM, still untested
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
