F4 power amplifier
F4 power amplifier
Old 6th June 2013, 06:38 PM   #3601
Navyblue is offline Navyblue  Singapore
I may be too quick to say that the voltage across the TL431 is stable. It is actually fluctuating at a range of about 30mV, whereas the other side is stable to at least 10mV (measurement limit). As to why it is so, I couldn't find out why. Measuring continuity between components , and checking visually, there seem to be nothing wrong. May be the TL431 is bad.
Old 6th June 2013, 07:58 PM   #3602
Triodethom is offline Triodethom  United States
Triodethom's Avatar
TL431 is not that costly replace it if you want. So the out put is stable ? If it below 10mv after it warms up run with it .
Old 13th June 2013, 08:28 PM   #3603
I replaced the TL431, but it doesn't help.
Since then I tried a lot of stuffs, and finally be able to narrow down the problem, which is at C1. Here are the gist.
- The reason that the DC fluctuation at output symptom is voltage across TL431 isn't as still as it can be.
- When I soldered a 220F electrolytic capacitor at C1, the problem appears.
- Replacing the 220F electrolytic capacitor does not solve the problem.
- Soldering a 47F film cap largely solved the problem, but soldering 220F electrolytic capacitor on it brings the problem back.
- If I connect the 220F electrolytic capacitor through wire with alligator clips, the problem disappears.
- If I clip the leads of the 220F electrolytic capacitor directly without the wire, the problem came back.
So I thought, may be I need the resirtance of the wire. So I tried adding a resistor (1Ω, 5Ω and 22Ω). If I clip the resistor leads directly, the problem remains. If I connect the resistor through wire with alligator clips, the problem disappear.
Why is it that the wire with alligator clips seems to posses magical property? Any ideas?
Old 13th June 2013, 09:17 PM   #3604
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
it's dirty (pic)
so , pics .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th June 2013, 02:30 PM   #3605
Dzius is offline Dzius  Poland
Dzius's Avatar
I've built 4 chanel F4 on IRFP240/9240 and everything seem to all right exept one thing. Both sides of my F4 are playing relatively dry comparing to F3 or F5. So I recon timbre of music to be not so impressive I expected. Simlilary like "Navyblue" I changed 220uF caps for different Elna silmic from differente source (thought the first ones were fake) but that didn't cure the problem. I sounds exactly the same. Any idea how it can be or just it's just like that ?
Old 15th June 2013, 02:33 PM   #3606
6L6 is offline 6L6  United States
6L6's Avatar
F4 power amplifier
What preamp are you using?
The F4 has almost no sound of it's own and passes on the character of the preamp.
Old 15th June 2013, 03:50 PM   #3607
generg is offline generg  Germany
generg's Avatar
F4 power amplifier
Default they all sound different....
and besides what 6L6 said, I would read Sarajans 6moons reviews of the F4 included especially in the F5 review and the J2 review and see if you can agree with some of his words....
and the First Wtt is......a really First Class PSS Idea
Old 15th June 2013, 03:59 PM   #3608
Zen Mod's Avatar
F4 power amplifier
ACA via small cap driving some squawker and F4 , driving woof .
woofwoof
squeeksqueek
gollugollum
Old 15th June 2013, 04:12 PM   #3609
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Disregard Srajan. He likes F5
...Shape the sound , Man!
Old 15th June 2013, 04:15 PM   #3610
generg's Avatar
F4 power amplifier
I thought it was F6.....
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
