F4 power amplifier - Page 358 - diyAudio
Old 17th April 2013, 08:57 PM   #3571
Thanks.
I am afraid I have another dumb question.
I picked this diode.
http://www.onsemi.com/pub_link/Colla...MBR40250-D.PDF
Do I need a heat sink? I couldn't make sense of the thermal graph.
Old 21st April 2013, 04:40 AM   #3572
Is there a specific reason that the design calls for 2 rectifier bridges? Why not just use a single bridge to create a bipolar supply? Or is it just for the increased current handling capability?
Old 21st April 2013, 09:21 AM   #3573
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
cleaner final gnd point ;
also - when using CT secondary , current imbalance between windings can induce sort of xformer buzz ; this way that's avoided
you can take that as Pa's words ( so granted ) even if I just recreate it by memory
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st April 2013, 11:11 AM   #3574
Thanks.
I intend to use 2 transformers, each having 2 x 18V secondary, to create a single power supply. So there are a few ways that I can hook them up.
The simplest seems to be each transformer in full wave rectification configuration, with one doing the positive and the other the negative. But I don't understand about the current imbalance thing . Would it cause the aforementioned problem? Or according to the oracle , I need to have one bridge on each transformer?
Old 21st April 2013, 11:25 AM   #3575
Zen Mod's Avatar
yup - one Graetz per xformer/winding ...... no headache
Old 13th May 2013, 10:15 PM   #3576
Just when I thought I am inches away from the glorious finish...
I have not adjusted the bias. On one of the channel, the output resistor measures about 120mV across. There isn't any measurable DC at output. Seems good.
However things aren't so good on the other channel. Most output resistor measures about 150mV, except 2 of the IRFP240. One measures about 70mV and the other about 220mV. There is about 1V DC at output. Questions:
1. I suppose those 2 IRFP240 are fried? Or only 1 of them?
2. Is it likely that other MOSFETs are fried too?
3. Is it possible that the MOSFETs are alright and there is merely a bad connection somewhere that cause these symptoms?
Old 13th May 2013, 10:25 PM   #3577
Zen Mod's Avatar
are those mosfets matched ?
Old 13th May 2013, 11:46 PM   #3578
The one and only
Nelson Pass's Avatar
If you match to .1V (which I recommend) then this is within range.
Your offset is off. Try adjusting the resistors from the supply to the bias circuit.
Old 14th May 2013, 02:15 AM   #3579
6L6 is offline 6L6  United States
6L6's Avatar
I totally forgot to post this link -
- Building the Pass/Firstwatt F4 -
A guide to building the Pass F4 amplifier.
Old 14th May 2013, 06:03 AM   #3580
Thanks guys.
The MOSFETs are supposed to be matched. However I can only take the seller's word for it.
Although I have not adjusted the offset too, I matched the trimpot resistance to the resistor on the negative rail. I don't know if this would ensure no DC offset, but this work for the other channel. My feeling is the MOSFET, no?
Edit:
I asked the seller to matched Vgs to 10mV for all 12 MOSFETs (2 channels). The seller provided the Vgs reading of each individual MOSFET, the numbers are indeed matched to under 10mV, but at unknown condition/parameters. From the pool of 12 I split them into 2 groups and each group has under 5mV variation. But as said I can only take the seller's word for it.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
