F4 power amplifier
F4 power amplifier
Old 11th April 2013, 09:05 PM   #3561
Navyblue is offline Navyblue  Singapore
I was about to decide on this, with 380 x 140 x 32mm heat sink per side. But would like to explore other alternatives.
Old 15th April 2013, 08:55 AM   #3562
Originally Posted by Nelson Pass View Post
Try a Jensen JT-123-ALCF as a 1:4 autoformer.
Originally Posted by Zen Mod View Post
two things , unfortunately :
1. I'm not Pa
2. yes , with Jensen , being xformer sans CT secondary , you must use one per leg
3. looking at schm you posted in #3390 , connection is like attached :
4. #3 and #4 are just to confuse you , considering two things mentioned
By that drawing, autoformer would be
BRN to GRY
VIO to BLU
GRN to YEL
RED = GROUND
ORG = OUT
BRN = IN
Correct me if I'm mistaken, ZM
Sorry to dig up these old posts.
If I were to replace C1 and C2 with an interstage transformer, is R3 and R4 still necessary?
And, would this be a suitable transformer?
EDCOR - XSM10K/10K
Old 15th April 2013, 03:02 PM   #3563
6L6 is offline 6L6  United States
6L6's Avatar
F4 power amplifier
I've got mine biased properly and running in stereo - (Changed R9 to 4.75K, bias pot has lots of range now)
Oh, wow... It's completely transparent.
Old 15th April 2013, 03:39 PM   #3564
generg is offline generg  Germany
generg's Avatar
F4 power amplifier
EDCOR - XSM10K/10K
is suitable...... but you have no gain by the xformer, donīt you want gain?
in the case you want, take a 1:4 or 1:5 xformer
and the First Wtt is......a really First Class PSS Idea
Old 15th April 2013, 03:59 PM   #3565
Thanks.
Sorry for the elementary question, when a transformer steps up, does it comes with extra penalty such as gain stage (i.e. distortion)? I suppose the extra current draw by the preceding stage is insignificant.
Also, can R3 and R4 be eliminated?
Old 15th April 2013, 04:24 PM   #3566
Triodethom is offline Triodethom  United States
Triodethom's Avatar
In post 2994 Zen mod shows a f4 without the buffer stating about a 10k load . Then the voltage on the rails could be raised some with out a problem I take it . giving more than 25 watt class A with in reason.
Old 15th April 2013, 04:34 PM   #3567
flg is offline flg  United States
flg's Avatar
Yes. There will be tradeoffs, the driving source should be many times lower source impeadance than the primary:secondary > load impeadance(3 FET gates and the biasing R's). You should go to: http://www.jensen-transformers.com/a...%20Chapter.pdf
So, when N.P. uses a buffer to drive a transformer, now you will understand why? Basically, if you want to do a turns ratio for the gain, you need a super buffer. You can probably get away with the best N and P JFETs in your drawer and use a B1 style (but you could do better). That might net you 15 ohm source Z. Squared times the turns ratio would give you the output Z of the secondary. And what is left on the input of the F4? 10k?
(15*15)*4(or 5)= your source impeadance into the F4 output stage. Are you only using it for midrange?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 15th April 2013, 05:46 PM   #3568
generg's Avatar
F4 power amplifier
Thanks.
the transformer step up is the main source of distortion as Nelson mentions in the M2 owner manual, but ....... many advanced people write that the distortion of such a small xormer, you might even go for a 1/4W version, is often more pleasant than the distortion of a regular gain stage.
And when you read the reviews of M2 for instance at Tone Audio there is much praise of clarity and darkness combined by this solution.
You can take the same input buffer like in F6, with or without degeneration (mind the voltage and Idss hints!) and drive the Jensen. Recommended input about 600R and output about 10k from your first Edcor try....
Old 16th April 2013, 04:17 PM   #3569
Thanks guys. I think I'll stick to the default this time round.
Is 1/4W resistor all around enough for the amp circuit? I am not sure about the current passing through R5 and R22.
Old 16th April 2013, 08:46 PM   #3570
generg's Avatar
F4 power amplifier
1/4W is good for R5 and R22.
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
