Old 22nd November 2012, 11:13 AM   #3521
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yes
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 24th November 2012, 07:02 PM   #3522
willamp is offline willamp  United States
willamp's Avatar
Hi All,
Getting close to finishing my dual mono F4 clone. It's only been powered up for about an hour and I was listening to it for 15 min or so. Sounds great with the tube pre-amp that is also mostly done. I'm going to let the F4 run a few hours on the bench and re-adjust the bias and offset in preparation for a full listening session tonight. HP339 is saying THD: ~0.0078% at 1 watt into 8 ohm. Real number is likely lower than that as I think the notch filter on the HP needs some work.
The case is the diyaudio deluxe 4u.
Anyway, thanks to Papa and everyone else for all the info you've posted to this site. Without it I'd still be listening to store bought stuff.
Last edited by willamp; 24th November 2012 at 07:17 PM. Reason: adding info for clarity
Old 24th November 2012, 07:38 PM   #3523
Zen Mod's Avatar
every stereo F4 deserves proper XLR on back plate
Old 24th November 2012, 07:50 PM   #3524
willamp's Avatar
Don't worry. 30 minutes with a saw and I can switch the RCA to XLR if/when I need to.
Old 24th November 2012, 07:55 PM   #3525
willamp's Avatar
Here's a question for ya
Look at the second waveform in my picture, 1st post (1st waveform is 1khz input). This is the HP distortion monitor output. This the signal sent to the meter after the notch filter. See how much fundamental frequency is in the signal? Shouldn't that have been removed? and isn't it throwing my measurements off?
thx
Old 24th November 2012, 10:09 PM   #3526
Zen Mod's Avatar
well - you must explain your measurement method , so we can decide what's lousy - your building , or measurement skills
Old 25th November 2012, 10:09 AM   #3527
willamp's Avatar
Well, lets disregard my analyzer question, probably not the right forum for that.
As for the F4: first listening session last night was most enjoyable. It sounds great in my system. Just what I was looking for.
Old 14th December 2012, 01:53 AM   #3528
Quick one: are two 2*26v 120va transformers good to power the f4?
I still have them lying around but am not sure regarding too high voltage and too low power...
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 14th December 2012, 06:15 AM   #3529
Zen Mod's Avatar
120VA is limiting factor - you'll need to decrease bias
also - Jfet's are approaching tricky voltages - you'll need to take care of their Idss .....
so - either degeneration or cascooding
Old 14th December 2012, 07:37 AM   #3530
In short no
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
