F4 power amplifier - Page 350 - diyAudio
Old 26th September 2012, 04:34 AM   #3491
Originally Posted by buzzforb View Post
If you got the gain, they got the grunt. That is biased at normal levels. If you are quazy, just bias them higher and raise rail voltage and you definitely have no issues. it is current amp, so it laughs at tough load. As for combinations, I have all boards in quesiton populated, its just matter of taking time to throw it together. I have always wanted tro try Lovoltech JFet SRPP FE for F4. Taylor it to specific Zin of jfet free F4 and you got an amp that can swing big V and shoot big I
Buzz - thanks for the input
You have me re-reading this thread and the BA3 thread
I would like to build a "bass" amp (driving SEAS w26s) to replace my Crown K1s.
Having done two headphone F4s with interstage transformers makes me lean to a full F4 with the same - love the simplicity - but there is the appeal of something new - the BA3
I also have been following the F6 thread and that is one intriguing amp. What would we do w/o DIY
Best
Bob
Old 30th September 2012, 04:49 AM   #3492
Hooked up my Jensen F4 to the Ravens in my system a couple of days ago
Kept the F3 driving the PHL midranges
Moved the Aleph 30s from Ravens to drive the SEAS W26 bass driver
First of all I must say that I forgot that the Alephs can put out in the lower range.
Overall I find that I have a wider soundstage, better localization of instruments. nice tight bass and a system that I can listen to without fatigue.
The transformer F4 continues to intrigue/fascinate me. Once and if I can get my head around it I would like to build a F6 and try it to drive the PHLs moving the F3 to the Ravens. Maybe the Ravens favor a current amp. Don't know but it could be an interesting experiment.I do know that the Crown K1s may be headed to CraigsList
Maybe a crazy question but could the F3 be used to drive a stock F4 (no interstage transformer)? Same question about the Aleph30 - can it be used to drive stock F4?
Best
Bob
Old 30th September 2012, 03:49 PM   #3493
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Best
Bob
both can drive F4 , even if real benefit one can expect only in case of F3 feeding F4 , if increased power is goal
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th November 2012, 11:16 PM   #3494
6L6 is online now 6L6  United States
6L6's Avatar
I have a quick question for the experts --
Are the transistors that buzzforb sells, the Fairchild FQA19N20C(FQA16n25C) and FQA12P20 , direct substitutes for the IRFP240 / IRFP9240 when building a F4?
Are any changes to the circuit required or suggested?
Thanks,
Jim
Old 13th November 2012, 12:14 AM   #3495
Zen Mod's Avatar
just toss them in
Old 13th November 2012, 12:27 AM   #3496
buzzforb's Avatar
I have more rif you need them
...Shape the sound , Man!
Old 13th November 2012, 12:30 AM   #3497
6L6's Avatar
Originally Posted by Zen Mod View Post
just toss them in
That's what I thought, but it never hurts to double check.
Thanks!
Old 17th November 2012, 03:15 PM   #3498
6L6's Avatar
Here's another question - how much input voltage would it take to drive a F4 from the XLR input to get 5 watt into 50ohm?
I know there is a way to compute that, but I haven't a clue to the formula.
Also, does the drive voltage requirement increase or decrease for a given output if you use the balanced vs. the RCA input?
Old 17th November 2012, 03:33 PM   #3499
Zen Mod's Avatar
let's go backwards
say that F4 will squeeze +/- 20V sine at output (round number because of clarity ; real life - it's in ballpark )
that's 40Vp-p
that's 40V/2 peak
that's (40V/2)/1.41 RMS
as P is U^2 / R
that's (for 8R) : 14V14^2 / 8 = 25W
now go backwards
Old 17th November 2012, 04:22 PM   #3500
6L6's Avatar
So if you have that same input signal of 40v p-p (14vRMS)
into 50R
14^2 / 50 = 8w ?
Is that correct?
Next question - with a 2v source (computer, Dac, CD player, etc...) how much signal would you get from 30db gain? (such as a BA-3 front end...) I'm not super clear on how db works...
And does using it (the BA-3) balanced change the gain or is it the same?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
