#3451 |
buzzforb,
what do you mean by this...? "You will see greater seperation in their response from signal chnages, but this can be minimized by paralleling devices."
and the First W tt is......a really First Class P SS Idea !
#3452 |
Just because they match up in terms of Vgs vs Id, does not mean that they have similar Yfs, so they will respond differently to an incoming signal. The datasheets show the 240 as having a Yfs of 7S and the 9240 having Y(g)fs of 4.2S. If a 1V sine wave is applied to both, you will get different responses. In truth, they are close enough that it is no big deal, as most music happens at very low power levels, but on more dramatic passages, with higher transients, you will have greater seperation, as the N channel part is able to provide more current for a given volt than the P channel part.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#3453 |
Thank you, yes I saw the different Y and the different Ciss and so on.
But what is the different Vgs of normally over one Volt doing? Distorsion? Or is it not important in class A. Maybe Iwill look at a book...... ![]()
#3454 |
As Nelson says, "it tends to favor the postive going waveform"
, a little second harmonic.
#3455 |
Thanks buzzforb!
#3456 | |
As generg pointed out matched irf240/irf9240 are available. As an experimentI could try a pair of these or stick with the 510/9510s . Have both I would use the Jensen JT-123-Flpch (purchased 4) mentioned in the F6 thread instead of the Jensen JT-123-ALCF (no longer available) Are C1 and C2 in the original HP circuit there to block DC. Are they necessary if a transformer is used Thanks |
#3457 |
you must point me to "original HP circuit"
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3458 |
#3459 | |
yes, they are still necessary where you are going to insert xformer , exactly ?
#3460 |
I used the schematic in 3399
Thanks |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
