#3411 |
when touching heatsink - is it laying on the floor as pictured , or you have it properly positioned , to ensure natural airflow ?
asking , just in case .......
my Papa is smarter than your Nelson ! tnx to |
#3412 |
As pictured. The heatsinks are resting on a aluminum plate laying on the floor.
#3413 |
hardly representative situation .
put them as intended - vertical , then try ensure proper distance to floor (raise them at least 5cm) - they need space to breath
#3414 | |
Did you check that every pair has the 200mA......? Only to be sure.....
and the First W tt is......a really First Class P SS Idea !
#3415 | ||
Is it advisable to change a tighter set of Vgs for the transistors? i already matched them to +/-0,02V beforehand. Quote:
#3416 | ||
#3417 | |
"By placing 1ohm source resistors on each transistor, we can assure adequate current sharing for a fairly wide range of VGS. In Class A bias, we will be operating at about 200mA/device, which will place 0.2V across each source resistor. A variation in VGS will cause the bias to be unequally distributed between the devices. For example, for a 4.6V device in parallel with a 4.5V device, the first will run at about 160mA at 6W and the second at about 240mA at 9W." You see how big the changes are from 4.6 to 4.5V Vgs! In this article he also describes the method to change the resistors to counteract to the differences. I think it is not necessary in your case. But if you have the will and the time.... http://www.firstwatt.com/pdf/art_matching.pdf When I compared some FW amps to my clones and they sounded much worse it was mostly the matching effort that could bring them nearer to Nelson Originals. (but never more than 80%)
#3418 | |
You could also follow his advice at look at one or two other points to get the more matched parts...
#3419 |
Thank you Generg, I will look through the articles and see if i can match the devices better next time. I shall not proceed further until i find matched parts. No point building a F4 if i cannot get the result at least 80% near to the orignal thing.
but how do you measure this aspect? It seems most F4 builder descibe the amp characteristic to that of water. Hope i can experience it too when i fine tune mine further.
#3420 |
.....the 80% is only a guess from my side! Saying that I succeeded getting the sound close to Nelson Original after some weeks......
![]() In the meantime I was a bit depressive and thought to buy an original from the Master..... ![]() and mind the Input J-fets too, I would suggest in this place an Idss of 10mA for the K170 and J74.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
