F4 power amplifier
F4 power amplifier
Old 24th June 2012, 10:39 PM   #3391
buzzforb is offline buzzforb  United States
buzzforb's Avatar
The Sowter mic input transformers for sale in swap meet would be a good inexpensive try at the concept. Sowter is a quality brand $30 can tb ebeat anywhere. If you like it, then you get to have fun trying different ones to find the perfect one. Ill be trying the sowter as soon as i get them.
...Shape the sound , Man!
Old 25th June 2012, 05:16 PM   #3392
flocchini is offline flocchini  United States
Originally Posted by flocchini View Post
Choky as you said
"- it's worth trying xformer as in M1 - nested between input buffer and output stage
- it's worth trying xformer connected as autoformer ; if you need drawing of that ,just say ."
With your schematic as reference would it be possible to connect transformer between junction of R4/R3 and junction of C1/C2.
I would use Jack Ellianos PVA2-N as generg favored it in post 23 of MAGMA thread - http://www.diyaudio.com/forums/pass-...ba-2-f4-3.html
I believe it could also be wired as an autoformer. Cost is nice as 4 of these would be less than the Lundahls
Cost of the Sowters buzzforb recommends if appropriate are even better. Haven't heard back from seller.
Bob
Old 25th June 2012, 05:26 PM   #3393
buzzforb's Avatar
He is out of town for the week. Patience comes to those who wait.
Old 25th June 2012, 05:36 PM   #3394
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
Bob
for your balanced F4 can iteration , you need xformer with center tapped secondary , or in other words - with two section secondary
either that , or using one xformer per leg ...... which isn't smartest thing if you can choose
I don't know does PVA2-N have CT secondary
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th June 2012, 07:43 PM   #3395
Choky
Is this not wise because of the variation of one transformer to the other?
Bob
Old 25th June 2012, 07:57 PM   #3396
Zen Mod's Avatar
F4 power amplifier
I'm living in believe that two phase balancing act is much more intimate , if happening in one magnetic circuit
one thing is , say , if you have normal M2 and you want to bridge it
another thing is if you're going to make balanced M2 from scratch
Old 25th June 2012, 08:11 PM   #3397
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F4 power amplifier
Try a Jensen JT-123-ALCF as a 1:4 autoformer.
Old 25th June 2012, 09:17 PM   #3398
buzzforb - thanks for info
Choky - I understand your belief that best sound comes from one magnetic circuit
Nelson - thanks for recommendation - a couple of questions if you don't mind - remember it takes time for this to sink in my brain
Are you recommending one of the Jensens in each of my R-, R+, L+, L- legs?
Can they be connected at junction of R3/R4 (input) and junction of C1/C2 (output) on the F4 board?
I think wiring as a autoformer is grounding brown lead, connecting red and orange and using that as input, connecting yellow/ green, connecting blue/violet and using grey as output (ref http://www.jensen-transformers.com/d...s/123alcf3.pdf)
Thanks again to all and for anyone looking for a headphone amp - a balanced F4 is at the top of my list
Old 25th June 2012, 10:01 PM   #3399
Zen Mod's Avatar
F4 power amplifier
two things , unfortunately :
1. I'm not Pa
2. yes , with Jensen , being xformer sans CT secondary , you must use one per leg
3. looking at schm you posted in #3390 , connection is like attached :
4. #3 and #4 are just to confuse you , considering two things mentioned
Old 25th June 2012, 10:06 PM   #3400
The one and only
F4 power amplifier
By that drawing, autoformer would be
BRN to GRY
VIO to BLU
GRN to YEL
RED = GROUND
ORG = OUT
BRN = IN
Correct me if I'm mistaken, ZM
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
