F4 power amplifier
F4 power amplifier
Old 23rd June 2012, 01:59 AM   #3381
flocchini is offline flocchini  United States
Choky
I looked at the data sheet and believe on the input side the two primary windings should be hooked up in parallel. ( 2 and 4 connected ; 1 and 5 connected.) positive phase connected to 2/4 and negative phase to 1/5.
Alternately 1 and 4 could be grounded and positive connected to 2 and negative to 5.
On the secondary side the center taps (6,9) should be grounded as you mention in previous post and plus output connected to 7 and negative phase to 10.
With a gain of 4x the 2V RMS from DAC should be raised to 8V
Old 23rd June 2012, 02:18 AM   #3382
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
what sort of signal you are using ?
ballanced ,symmetric , non-ballanced ?
if you use primaries connected in series , with CT grounded at signal side , and secondaries in series - with their CT connected to gnd at receiving side .......... you'll have both perfect symmetric balanced ........ and gain of 2:8
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd June 2012, 02:18 AM   #3383
regal is offline regal  United States
Originally Posted by flocchini View Post
Choky
That looks ideal for the Hifimans, only gotcha would be the transformer distortion at low frequencies (which are usually worse the larger the winding ration ie gain). Would be nice to find a simple low distortion 2-4x jfet gain/buffer design to compare.
Old 23rd June 2012, 02:32 AM   #3384
Zen Mod's Avatar
F4 power amplifier
well , sometimes is nice to use xformer to get rid of absolute DC offset , as is case with diff. DAC chip output
several times I found that solution better than Jfet buffers with caps in signal route
whatever - there is supplement pic to my previos post
Old 23rd June 2012, 02:36 AM   #3385
Thanks regal and Zen Mod
My input signal is balanced.
May be time to experiment
Old 23rd June 2012, 02:42 AM   #3386
Zen Mod's Avatar
F4 power amplifier
off course that you can skip connecting primary CT to signal gnd side
as I'm saying frequently - gnd is just state of mind
few tips :
-depending of signal source impedance , freq. sweep will show does secondaries need some loading or not
- it's worth trying xformer as in M1 - nested between input buffer and output stage
- it's worth trying xformer connected as autoformer ; if you need drawing of that ,just say .
Old 23rd June 2012, 01:45 PM   #3387
few tips :
I would need drawing
Old 23rd June 2012, 02:01 PM   #3388
Zen Mod's Avatar
F4 power amplifier
when you choose exact xformer for first test , just say
Old 23rd June 2012, 03:07 PM   #3389
will do
Old 24th June 2012, 09:34 PM   #3390
Choky as you said
"- it's worth trying xformer as in M1 - nested between input buffer and output stage
- it's worth trying xformer connected as autoformer ; if you need drawing of that ,just say ."
With your schematic as reference would it be possible to connect transformer between junction of R4/R3 and junction of C1/C2.
I would use Jack Ellianos PVA2-N as generg favored it in post 23 of MAGMA thread - http://www.diyaudio.com/forums/pass-...ba-2-f4-3.html
I believe it could also be wired as an autoformer. Cost is nice as 4 of these would be less than the Lundahls
Bob
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
