Old 21st June 2012, 07:49 PM   #3371
flg is offline flg  United States
flg's Avatar
Originally Posted by Zen Mod View Post
...it is , generally
I had the xfrmr connection in mind. As if the rest of the circuit were an F4
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 21st June 2012, 07:51 PM   #3372
[QUOTE=Zen Mod;3067691]link to xformer data ?
Electra-Print.com PVA Passive Audio Pre-Amplifier
Electra-Print.com Special Use Transformers
Sorry
Old 21st June 2012, 08:12 PM   #3373
buzzforb's Avatar
FYI,
Guy in Swap Meet selling sowter mic input transfomers for very reasonable price of 20lbs.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 21st June 2012, 08:35 PM   #3374
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
[QUOTE=flocchini;3067708]
no need to sorry
anyway - try to find some xformer with 1:1+1 ratio ,where primary impedance is marked for line level duty ( loading in range of 10K)
dual secondary (or one , center tapped ) is necessity , to have phase splitting function of xformer
tip - for better behavior in freq. domain , you can wire xformer as aoutoformer ....... in other words - as center tapped choke with multiple taps
dunno ..... on your side of Big Splash which xformers you can try
so - there is possible candidate , as example :
http://www.lundahl.se/pdf/1592.pdf
look at "Phase splitting 1:1+1 input " connection picture ; it's interesting for unbalanced to balanced conversion
in your case , as you already have balanced source , you can use it as 1+1 : 1+1 , where both primary and secondary center taps must be grounded , for perfect balanced function
conclusion - you can't use electra print , because of lack of dual secondaries ......... and low impedance primary
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 21st June 2012, 08:56 PM   #3375
Originally Posted by buzzforb View Post
FYI,
Thank you
Old 22nd June 2012, 07:58 AM   #3376
regal is offline regal  United States
Originally Posted by flocchini View Post
I have been listening to my balanced F4 driven by Pass X10 and fed by my Mc through a Buffalo II for about 3 weeks now. Running with 300mA bias at 15V.
I have to say this setup is absolutely superb with my HiFi Man 500s and with modded Denon 2000s, The bass is low and tight. There is very nice detail and the female vocalists (Etta James, Eva Cassidy, Jacintha, Nora Jones ) sound incredible. Why did I wait so long to do this. Highly recommended.
Thanks Choky and all who contributed to this thread/project.
I wonder what it would sound like with a MAGMA front end
Best
Bob
I have a pair of Hifiman HE-HLE (I think the sucessor to the HE-500), been following this thread as they need an unusual amount of power (~1=2W) for headphones.
I really think you will have a big improvement with a gain stage, no mater how big your F4 without at least a 6Vrms voltage swing these phones can sound better, at least for music with a bigger dynamic range.
Does the Magma include a VAS (or other gain) ?
Old 22nd June 2012, 08:26 AM   #3377
Zen Mod's Avatar
it was presumable that xformer , as connected , have gain in range of 14-15db
Old 22nd June 2012, 09:13 AM   #3378
Yes for the hifimans the lundhal 1+1:1+1 won't give the gain. A 1+1:1+1+1+1 may be a good compromise, just know from my experience with these ortho headphones perform best with 6Vrms swing headroom (measurements taken listening to my lowest level recording with the highest dynamics volume pot left in same position then running a 0dbs 1khz sine wave for measurement.) I've found typical recording listening level around 3-4rms (at 0dbs). Obviously most of the music content is lower but these thing want that headroom. They are rated at 87db/mW but I think at higher levels their efficiency drops. They are oddballs, but sound amazing and I've been considering the F4 buffer just for them (ethusiastic to see others thinking along the same lines.) Currently I am using a commercial hybrid + p-p mosfet output class A-B design.
Old 22nd June 2012, 09:27 PM   #3379
I have used a Aleph 30 with the HiFi Man 500s. Sounds extremely good.
In my opinion and I will continue to listen the balanced F4 driven by a Pass Xp -10 is right there with the Aleph 30.
I would like to try a Buffalo II with Volumite and Legato drive the F4 directly.
I am bit confused about transformers. Does the Lundahl 1592 have no voltage gain?
Would a Lundahl1674(1+1:4+4)http://www.lundahl.se/pdfs/datash/1674.pdf
have gain?
If someone could point me to a place to read more I will do my homework
Bob
Old 22nd June 2012, 09:44 PM   #3380
Zen Mod's Avatar
numbers left are for primary windings , numbers right are for secondary windings
their ratio means voltage gain
you can wire LL1674 in several ways - just read datasheet and think
then ask
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
