#3321 | |
I should know better.The circuit is really only to show the current mirror/level shifter mod. |
#3322 |
Hi
I am building a stereo F4 (r0 6/4/07) with 20v dual secondary transformer(400va). Since I have higher voltage rail(+-26.5v after rectification and filtering), I increased R5 and R22 to reduce the voltage for JFETS. I changed 1K -> 2.4K and 750R -> 2.2K, then I get about +-20V for JFETS with everything connected. My questions are: 1. When you use 18v secondary transformers, what voltage do you get for JFETS? 2. When I change the values for R5 and R22, do I need to adjust the bootstraping resistors(R24 and R25) also? 3. Is there anything else I need to consider to use higher voltage rail? Thank you. |
#3323 |
you don't need to change anything , if difference is just 2V
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3324 |
Thank you for the quick response.
When I measure the voltage going into the JFETS, it is +-25.7v which I think is a little bit over the maximum and I wanted to bring it down to around +-20v. I have studied the schematics and read the postings in this forum, but I still do not understand the bootstraping circuit. If C3 and C4 were grounded, they would simply form a RC filter for JFETS with R5 and R22. But since C3 and C4 are connected to the output with resistors, I GUESS they provide some sort of feedback from the output signal. If the bootstrap network is using feedback, do values of R24 and R25 not determin the feedback amount? Thank you |
#3325 |
According to datasheet IRFP240 has transconductance min 6.9S and IRFP9240 has 4.2S. Why not to use different value of source reistor to compensate? For example 0.47R with IRFP240 and 0.22R with IRFP9240.
#3326 | |
Early on in the F5 thread, Nelson said that the source resistors for the output MOSFETs could be played around with to lower THD% Increasing this resistor has the effect of lowering transconductance at high current --- you should get Bob Cordell's book "Designing Audio power Amplifiers" -- it's on page 233. |
#3327 |
Can someone point me to the lateral mofset schematic of the F4?
Also should I expect better performance than the Doede Tumos that simulated at -65db 2H with 6Vrms output ? |
#3328 | |
#3329 |
Just to be sure. I have aikido preamp driving directly crippled output stage. Aikido has 500 Ohm output impedance and 8mA max output current capability. Is 8mA output current able to drive the crippled F4 without any problems?
#3330 |
well , good enough
but you can always do better
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
