F4 power amplifier
F4 power amplifier
Old 12th April 2007, 09:21 PM   #321
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Originally posted by Nelson Pass
When in doubt, Plitron.
Or amplimo ?
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 12th April 2007, 10:00 PM   #322
Jaac's Avatar
Originally posted by Variac
OK, I searched, but I haven't seen a reference to what a reasonable VA rating would be for a single transformer to feed both channels of the F4 ....
maybe this one is a good option for you (stated in the USA)
toroid on ebay
Old 13th April 2007, 05:47 AM   #323
apassgear is offline apassgear  Mexico
apassgear's Avatar
Thanks Choky, you did my homework
Old 13th April 2007, 01:17 PM   #324
Darry is offline Darry  France
Default F4 power amplifier
Mr. Pass,
I am very interested by your F4 Firstwatt amplifier , no feedback, no voltage gain. My tube préamplifier have an output level in extensively sufficient voltage (Unbalanced and balanced mode ) for a good working of the F4.
I have Martin Logan Vantage speakers. (sensitivity 92dB, nominal, impedance 4ohms)
The Vantage uses a 8" aluminum-cone woofer along with a 200W amplifier (active subwoofer) and a passive traditional electrostatic transducer. (Crosssover frequency 400Hz).
But this speakers have a minimal impedance of 1ohm to 20KHz.
I know that there is not a lot of energy to 20KHz, also, can you say to me if you made tests with a F4 on the low impedances. The working is it correct ?
What configuration of the F4 is preferable with my MartinLogan?
Must me to add other pairs of Mosfet?
Thank you for your answer
Darry
Old 13th April 2007, 02:16 PM   #325
cviller is offline cviller  Canada
cviller's Avatar
I have received some requests for my shortened layout, so I thought I could just as well upload it.
The space between transistors is 4cm and the whole board is 25cm long. I have only marked one mounting hole, but it should be possible to drill at least one more somewhere, so you can mount it as nice as steenoe did it!!
Component numbers are the same as papas, except for the prefix 1xx on one of the channels.
ps and pdf files along with a couple of notes:
http://viller.org/audio/2007apr_f4/
Old 13th April 2007, 07:56 PM   #326
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F4 power amplifier
Default Re: F4 power amplifier
I have not tested the amplifier into 1 ohm, just 2 ohms.
For the ML's I recommend balanced drive with the stock
circuit.
If you need more current, perhaps increase the value of
the protection zener diodes.
Old 13th April 2007, 09:14 PM   #327
Default F4
M. Pass, thank you very much for your answer
Darry
Old 13th April 2007, 11:05 PM   #328
Samuel Jayaraj is offline Samuel Jayaraj  India
I have almost the entire BOM for F4s, well, almost. The concern is that the input JFETs are nearly impossible to obtain in my country. I do have a bunch of BF244, BF256, 2N5461, 2N5486, a couple of 2N5459s and J111s and nothing else. Which of these can I use to get the F4 idea off the ground.
Anyone on this? I'd really appreciate inputs!
Sam
Old 13th April 2007, 11:44 PM   #329
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
besides needed Vds (look at original used in F4) use ones with highest xconductance you can find.
even two in parallel if needed
hehe-if Babo can do with two certainly non complementary paired.........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th April 2007, 01:27 AM   #330
GRollins is offline GRollins  United States
I confess that I'm still underwhelmed by the idea of using such different parts in the front end...but yes, music can be made to come out if you try hard enough.
I would suggest the use of a pot between the Sources of unmatched JFETs. Each end of the pot goes to a Source. The wiper becomes the output node. Set the pot such that the DC offset (relative to ground) is least. Use the smallest value pot you can get away with. If 10 Ohms will do it, then use 10...if it takes 50 Ohms or 100 Ohms, then so be it. If you're finding that you need something like 500 or 1000 Ohms, try different JFETs.
No, you won't get DC at the output--the DC blocking caps will see to that. But don't say that I didn't warn you if you test the distortion and find that it's much, much higher than you expected.
By all means, experiment, but do so intelligently.
Grey
P.S.: I'm surprised that no one has asked if you can use MOSFETs at the input. The answer is yes, but it will take a few more parts. If you want, I suppose you could call this Hint #3, although it's not necessarily headed down the same path as #1 and #2.
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
