F4 power amplifier - Page 328 - diyAudio
Old 30th January 2012, 12:26 AM   #3271
luvdunhill's Avatar
Is there any reason to try adding a swamping resistor across my DX4 TP1 / F4 combo? I can think of a few cases (transformer coupled amp maybe?) that this might make sense, but not sure if it is worth trying in my case.
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 30th January 2012, 01:01 AM   #3272
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
well - you can do that with some intention ........
but - which one ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th January 2012, 02:42 AM   #3273
luvdunhill's Avatar
but - which one ?
Better sound? Better low end bass? Sanity that I tried something?
Old 2nd February 2012, 11:15 AM   #3274
Dzius is offline Dzius  Poland
Dzius's Avatar
Can we play with harmonic distortion character (2nd/3rd ratio) of F4 by putting P3 (200 Ohm) over R3 and R4 (source resistors of JFets), like we do in case of F5 ?
Old 2nd February 2012, 01:39 PM   #3275
Zen Mod's Avatar
presumably not , at least not in same amount - just because that's buffer stage - without voltage gain
Old 2nd February 2012, 03:32 PM   #3276
jackinnj's Avatar
The output devices are recommended to be Vgs matched +/- 0.02V -- but the gm of the two halves may be different -- in which case adjusting the source resistors on the MOSFETs may have some benefit -- but you've got 3 on each side so it will be a real headache!
Old 6th February 2012, 05:45 AM   #3277
Dzius's Avatar
Proper answer to my question can be found in the Nelson article
http://www.firstwatt.com/pdf/art_sweet_spot.pdf page 14 -15.
Yes you can change amount of distortion by trimming value of Jfet source resistors.
But change is not so dramatic in absolute numbers. So Zen Mod is right about it.
Old 6th February 2012, 08:50 AM   #3278
Audiofanatic's Avatar
Talking Choky is always right !
He knows everything about pass amps, don't forget, he's Papa's son
Audiofanatic
Be nice to animals.
Old 8th February 2012, 12:46 AM   #3279
Not being willing to read 51 pages of blurbs, I'll just ask--
1. Are Cs 1 and 2 signal-coupling capacitors?
2. If so, what is the load impedance for filter-point calc?
3. Can the cap-value be changed to create a hi-pass filter in the audible range for a speaker that requires one? That speaker is a Vandersteen 5A that needs a filterpoint between 50 and 100 Hz.
Thanx much in advance to the much-more-knowledgable-than-I (and that doesn't take much) who answer.
Old 8th February 2012, 04:16 AM   #3280
Zen Mod's Avatar
1. sort of , but not exactly
2. it's not constant vs. frequency
3. read #2
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
