Old 10th May 2011, 08:09 AM   #3091
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
in Italy - look for Icar
that's enough - premium quality , even if Italian
joking of course .......
Forza Vale !
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 10th May 2011, 09:46 AM   #3092
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by pjgregory View Post
Do you have a manufacture
If you hand Goldmund $10K for Zeus' 1st wife, you receive one motor run cap for free.
Not so much,.......if it says "ZM" in the corner.
Old 10th May 2011, 01:58 PM   #3093
Default F4 - Cases and Heatsinks
The courier arrived today with two 5U 400mm cases from HiFi200. Great Italian craftsmanship. They are listed as "Pesante Dissipante" which literally translated means "Heavy Dissipater". Well they certainly are heavy - the courier left them on the front step rather than risk a hernia carrying them into the house.
As I suspected, each side heat-sink is in two parts. So now it's off to find some copper strip to thermally connect the six output JFETS.
(I am still worried about the small pile of screws leftover after assembly - never a good sign.)
PJG
Old 10th May 2011, 02:31 PM   #3094
tinitus is offline tinitus  Europe
PJG
not if it were an engine
but in this 'case', who is counting
Old 1st August 2011, 11:09 AM   #3095
buzzforb's Avatar
Originally Posted by Zen Mod View Post
well - there is a small tweak available for you :
omit output caps on , omit everything in front of two electrolyt caps on F4 input ( tossing out jfet buffer and everything related) , bypassing two elcos with 10-68nF polycarbonats ........ then tell me what's your impression
yeah ....... but only when I'm forgetting fact that I'm spitting image of Modesty Blaze
Modesty Blaise - Wikipedia, the free encyclopedia
Does a power buffer like the F4 benefit from SUSY affect created in Pumpkin FE. Having no V gain does it still benefit from cancellation. Also, any insight into why Nelson uses different buffer on BA amps. Is it just to be able to extend Class A bias further before going into AB?
Old 1st August 2011, 12:04 PM   #3096
juma is offline juma  Serbia
juma's Avatar
Originally Posted by buzzforb View Post
Does a power buffer like the F4 benefit from SUSY affect created in Pumpkin FE. Having no V gain does it still benefit from cancellation. ...AB?
Yes it does, but only if F4 is included in SuSy feedback loop.
Old 1st August 2011, 01:10 PM   #3097
buzzforb's Avatar
Thanks Juma. Do you happen to have Spice model for Toshiba fets.
Old 1st August 2011, 04:26 PM   #3098
juma's Avatar
Only for small JFETs (k170/j74), but they are omnipresent anyway...
I suppose you are hunting for the big ones ?
Old 1st August 2011, 05:36 PM   #3099
buzzforb's Avatar
Yeah, looking for the 2sk2103/313. Not really experienced enough to just start building stuff. Would like to see if PSpice says it will not blow up. Oh well. I was going to try the OPA1632 with small F4 or F5 output. may use simpler Jfet FE and try SUSY.
Old 1st August 2011, 09:08 PM   #3100
juma's Avatar
... Not really experienced enough to just start building stuff...
There's nothing much to it: Vgs controls the Id which should be kept under 1A (2A peak if you keep the k2013/j313 reasonably cool). Basic stuff about MOSFETs and three ways to use them are described in Mr. Pass' F5 paper. That's all you need to get started.
Start with simple circuits, use the datasheets, analyze your results and understanding will come. You can't really depend on sims - they won't tell you the whole truth, but they can save you some time by calculating static parameters for you (after you learn how to do that manually).
Knowledge has never been so accessible, you just need to put some effort into it....
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
