F4 power amplifier - Page 306 - diyAudio
Old 24th April 2011, 05:18 PM   #3051
The one and only
Nelson Pass's Avatar
It's worth noting that the Burning Amp front ends are also
happy driving F4 type circuits.
When Wayne was designing the soon-to-be-released XP30
line stage, I requested a couple features:
1) Enough voltage and gain to drive a 300W power follower
2) A low enough output impedance to drive a bank of Fets.
Old 24th April 2011, 09:19 PM   #3052
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yup
and - because they're similar/same as discrete OP/AlephwithoutAlephCCSbutwithbootstrappedshebang - they can be made balanced/X-ed in same way as Aleph became X
so - good enough to feed revised concept amps ?
will it drive F4 ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 25th April 2011, 01:40 PM   #3053
cjkpkg is offline cjkpkg  United States
And there are even PCB's available...VERY interesting...It would seem to be fairly easy to integrate this front end into an F4 chassis...
Old 25th April 2011, 03:55 PM   #3054
davelang's Avatar
Are there any problems or issues with using computer grade 10k uf caps in the Pass F4 and F5 power supplies other than cost and size? I was surprised to see the small form factor caps in both the commercial and clone products. I am not an engineer but every amp I have ever built has used the computer grade products.
Old 25th April 2011, 04:18 PM   #3055
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
No problem, CG's are LL types and have high surge values, just cost.
Modern ones in that low uF range, as the Panies, aren't half bad though.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
Old 25th April 2011, 06:29 PM   #3056
davelang's Avatar
ok, but does surge factor have any sonic effect? What is a Panie(s)?
thanks
Old 26th April 2011, 03:38 PM   #3057
RKH is offline RKH  United States
What is a Panie(s)?
me thinks Panasonic... but I could be incorrect
Lighten up while you still can ...
Old 26th April 2011, 03:49 PM   #3058
jackinnj's Avatar
thanks
it's what you call your wife in Polish (panie=lady) and there should be a surge factor involved in response.
Old 26th April 2011, 05:52 PM   #3059
My bad, sounded like you turned Panicsonic.
Papa still shops CG's for his main event, though CDE nowadays, instead of Mallory computer grade specials in the Threshold years.
Panasonics are much cheaper (new ones) than special long life types, datasheet and experience tells that they're good.
Even an 85C TS-UP type lasts 50K hrs minimum, has 25% surge capability, good ripple numbers.
CG or off the rack items nowadays has more to do with reliability, less with sound quality.
(i still favor boutique items, but not for wimpy stuff)
See, every J is a joker.
Old 30th April 2011, 10:00 PM   #3060
Got one channel done...Looks like with the sinks I have 250mv will be the max...not bad at all.
Need to get the other channel connected and then take it for a test run with the JFET BOZ...
I am very encouraged by how easy this has gone together so far...
F4
Antek 3218 xformer
Antek chassis
CVILLER amp boards
PDANIEL psu boards
Vishay/Panasonic resistors
FETS etc...from TechDIY - Thanks Jack!
Thank you DIYAUDIO.com!!!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
