F4 power amplifier - Page 299 - diyAudio
Old 27th January 2010, 02:31 PM   #2981
Skorpio is offline Skorpio  Denmark
Originally Posted by Nelson Pass View Post
If you have a source which can drive 5 Kohm and a couple hundred pF,
you can dispense with the JFETs altogether and simply drive the Gates
of the Mosfets.
A little more work, and you can use a single pair of Mosfets and raise
the impedances of the bias circuit, and then it would be about 22K and 70 pF.
I would like to try without the JFET buffer and connect my Tube preamp (cathode follower output 12AU7) directly to MOS-FET output stage.
#1: Would there be any issues with bias setting (drift, optimal values, etc.) with one set of MOS-FETs? I would like to make bias selectable (low and high), where low would be for muzak and around 100-300mA...
#2: If the two 220uF capacitors are lifted from ground and connected to output terminal instead, they would bootstrap the input and making the input impedance higher (and load lighter for the preamp), correct?
Old 27th January 2010, 02:47 PM   #2982
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if that's plain Jane CF - just forget . in that case - leave buffer stage in .
you can find one pair mosfets output iteration on few first pages of thread .... bufferless little later
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th January 2010, 05:31 PM   #2983
The one and only
Nelson Pass's Avatar
Of course you could try it and see what you get.
Old 27th January 2010, 05:58 PM   #2984
vitalstates's Avatar
Originally Posted by diyray View Post
I can't find any info. other than 1 volt .05 (pre-out). Maybe it does I don't know. They don't give enough info. in the manual to know.
Onkyo Europe - PR-SC5507
here are some figures I took some time back...I can't remember why I did them so You'll have to take them as they are....they might address your question
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 28th January 2010, 10:07 AM   #2985
I have tried and found the following up till now:
Standard: input impedance= 5k, gain approx. 0.93gg
Bootstrapped: input impedance= 64k, gain approx. 0.93gg
I have added a switch to be able to select between the two, but with my tube prestage bootstrapping is best.
Next step will be lowering the two 220uF input capacitors to 10uF PS
I will also like a switch to change bias from approv 1A to 0.3A, will this could operate without major problems during operation?
Old 28th January 2010, 07:53 PM   #2986
The one and only
No. But the DC offset is likely to change.
Old 15th February 2010, 10:18 AM   #2987
generg is offline generg  Germany
generg's Avatar
Hi Zen Mod,
why didn´t you tell me how wonderfull F4 with Pumpkin sounds.........?
.... in the moment F5 lies in the corner.
and the First Wtt is......a really First Class PSS Idea
Old 15th February 2010, 04:05 PM   #2988
The one and only
Zen Mod is a man of great modesty.
Old 15th February 2010, 04:23 PM   #2989
generg's Avatar
He will be happy to hear this from You!
Old 15th February 2010, 04:25 PM   #2990
Audiofanatic's Avatar
Default Zen Mod, Choky !
He already know this
Best regards,
Audiofanatic
Be nice to animals.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
