F4 power amplifier - Page 290 - diyAudio
Old 25th April 2009, 07:55 PM   #2891
Liliya is offline Liliya  Norway
Default My F4 and Aikido project
To power Aikido I use Bas PCB with some changes. I use chokes instead of regular resistors. The sound is very much to my taste.
Old 25th April 2009, 07:57 PM   #2892
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Default @Liliya
real DIY
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th April 2009, 08:50 PM   #2893
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: @Liliya
Originally posted by Zen Mod
real DIY
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 25th April 2009, 11:45 PM   #2894
Default My F4 and Aikidoproject
Both channels into the chassis.
Old 25th April 2009, 11:50 PM   #2895
A closer look at the FETs mounted with Norwegian crowns (money)
screws and nuts in brass.
Old 26th April 2009, 12:03 AM   #2896
The next floor, the comlete Aikido stage, ready for mounting
Old 26th April 2009, 12:06 AM   #2897
The Aikido stage well into the chassis. Its vry tight.
Old 26th April 2009, 12:12 AM   #2898
With the frontplate on
Old 26th April 2009, 12:33 AM   #2899
This is a very fine amplifier with at very big soundstage. The unit is ment to be take care of the 60- 600 Hz range on my
Magnepan 1.6 loudspeaker. The crossover is a DCX 2496(modded)
But I have a ripple problem in one channel.
I have started a new thread on this forum (Tubes): "Grounding Aikido and F4" where I try to describe this problem.
May be it would have been a better idea to ask other members
for help in this thread??
I do hope for some good adwises before my hair turn grey.
Old 26th April 2009, 01:26 AM   #2900
luvdunhill's Avatar
Originally posted by spencer
I have reduce the source resistor to 0.245 ohm (0.51//0.47) due to good match of the mosfets.
Did you just reduce the value of the source resistor until the voltage was a certain percentage different on all the MOSFETs? What's a good guideline on how different the voltage drop across resistors can be and still have good performance?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright 1999-2017 diyAudio
