F4 power amplifier
F4 power amplifier
Old 18th June 2008, 05:13 PM   #2521
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by Zen Mod
well - I have another impression - they all were just looking WTF Papa is doing with that amp .......
No more toys for that gentleman
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 18th June 2008, 05:16 PM   #2522
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
F4 power amplifier
My tall tower has worked very well, but it is 6" square, and allows a lot of air flow through it- in fact more than normal because of the stack effect. A finned heatsink won't get this kind of air flow as the channels are relatively small.. Note that Nelson uses his fins horizontally, offending all purists, and they work fine. The tower gives a small footprint and like a big V8 engine, it works by having lots of inches! - about 25% more surface area than Nelson's commercial F4's. Magura predicted disaster for it and insisted on additional heatsinks, but it works fine even after I scraped the extra sinks off... I am rebuilding it for a second time and it is finally of a quality that I can live with. The show version was a mess and needed to be rewired..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 18th June 2008, 05:33 PM   #2523
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by Magura
just waste as the efficiency decreases dramatically at over 6 inches.
Something i've told all my girlfriends many times.
The Winged heatsink is actually pretty smart engineering.
Old 18th June 2008, 05:43 PM   #2524
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
I personally liked the channels hanging off the chassis. Kinda like christmas tree ornaments. They had a good pic in the AudioXpress article that covered the event.
Chris
Old 18th June 2008, 05:50 PM   #2525
diyAudio Editor
Variac's Avatar
F4 power amplifier
Yeah, but the boards kept getting moved around so various pins broke off the output devices. That's kind of sad. The repairs to the amps should have been done in a week, but I have a lot of other stuff to do like knocking member's heads together, sortin the Off Topic Pumpkin thread, etc. Also I wanted to take the time to make them something that I would feel are finished.
Certainly shorter, vertical heatsinks are more efficient- in fact I was considering
cutting some of the PAss heatsinks I got at Burning amp to use them vertically on a new project but then decided: naah! they have wide fin spacing, and I think, as I mentioned above, that increases the airflow..
Old 18th June 2008, 06:02 PM   #2526
Variac,
Do you have the AX issue with BA article? Magura wants (a scan of) it and I didn't buy the issue. I just read it at a bookstore.
Chris
Old 18th June 2008, 06:24 PM   #2527
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
Magura
I think that Papa already have 'nuff his own toys ....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th June 2008, 07:25 PM   #2528
Blitz is offline Blitz  Germany
Ok, my PSU-trip continues...today I changed the setup of the 4-pole Jensen's and paralleled them, so that each input is in parallel and each output as well. Before, the output of one 47000uF was connected to the input of the next one, so that the current need to go through the each of them which multiplies impedance.
Some technical observations: BEfore, I have on the 24v+ 0.3mV ripple (when having them in series). Now I have 80mV ripple.
Again, No CRC, both setups have no resistor or coil/choke.
I put as well on the output of the Jensens a 0.1uF Mundorf Supreme MKP Cap (more or less inductance.free).
So, how did the sound changed ? MAybe I need to relax more, take more time. My iitial impression:
More power and basis in the bass department. IN total warmer sounding, blacker. On the down-side: Less resolution, less refined, less 3D-space. The formerly huge soundstage is now more flat, more 2D. Instruments / voices seems to be bigger.
Can that be ? What are your experiences when playing with the PSU ?
Old 18th June 2008, 07:28 PM   #2529
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F4 power amplifier
Back to the noise problem, how about just shorting the inputs
to ground right at the input jacks - no external connection, and
reporting pack on the noise?
Old 18th June 2008, 09:41 PM   #2530
bubba177 is offline bubba177  United States
dead quiet !!!!!!!!!!!!!bubba
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
