Old 10th June 2008, 07:13 PM   #2391
Manu is offline Manu  Europe
Manu's Avatar
Originally posted by Zen Mod
that tells you something ?
For myself, I usually don't need Starthilfe ... thanks
Thanks for hints.
Old 10th June 2008, 07:21 PM   #2392
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Even John Curl called them Motor Start caps in his thread, , but even he MEANT Motor RUN caps. Motor run caps are polyprop in oil- yummy!
Old 10th June 2008, 07:21 PM   #2393
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
My bad, a motor start cap is an electrolytic, motor run is polyprop foil.
I tried the motor runnners on the P1.7, not all that bad really.
(If it turns into a sour treat, at least i can repair each of the washers and dryers 200 times, should easily last me to the next millenium in my nuke bunker)
Not so much,.......if it says "ZM" in the corner.
Old 10th June 2008, 07:28 PM   #2394
Manu's Avatar
Imagine a PSU which only last a 1/2 second.
Even for minimalistic Music, its too short...
Old 10th June 2008, 07:30 PM   #2395
You could make a CD like that and call yourself 50 PerCent
Old 10th June 2008, 07:33 PM   #2396
Manu's Avatar
Mister "9 1/2 seconds" ... much better.
Old 10th June 2008, 07:40 PM   #2397
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
who is John Curl ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 10th June 2008, 08:16 PM   #2398
Magura is offline Magura  Denmark
Magura's Avatar
Motor run caps are plain metalized PP caps, but mostly better quality that the so-called audio caps.
Comar makes some of the best, and they happen to be cheap as well.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 11th June 2008, 08:46 PM   #2399
has anyone had a hum problem with the F4? i have a 2 inch ground bussbar with signal ground on one end and speaker and power supply grounds attached on the other end with the thermistor at that end going to chassis ground with power earth ground at that point on the chassis also.----i have tried grounding the rca grounds together and tried bypassing the thermistor but none of that makes a difference. my rectifier diodes are mounted a couple of inches from the output pcb --is this to close? maybe some stray ac? hum is the same in both channels and doesn't vary with all the pushing and prodding i do. please give me some advice -mark
Old 12th June 2008, 12:32 AM   #2400
The one and only
Nelson Pass's Avatar
Maybe you want to put all the power supply grounds on one end
and all the signal bearing grounds on the other end (including
the speaker returns) At this quiet end a power thermistor to the
chassis which is directly attached to AC outlet ground.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
