F4 power amplifier - Page 230 - diyAudio
Old 15th May 2008, 09:24 PM   #2291
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Yeah, i've been thinking of getting into the virtual joint business, oldfashioned quality schit doesn't cut it anymore in this pulmonary awareness day and age.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 15th May 2008, 09:26 PM   #2292
Paper mache horn fabricator
carpenter's Avatar
Originally posted by GRollins
Virtual smoke is much cheaper than the real kind.
Grey
Ain't that the truth.
I'm trying to determine if I'm blowin' up the amp. I suppose that if the sim says the voltage and current are within device specs, I'm ok.
Thanks Grey, Nelson.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 15th May 2008, 09:28 PM   #2293
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
cwayzee dutchie
whatever is that drek - you smokin' or usin' these days - send a little to me
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 15th May 2008, 09:52 PM   #2294
jimbo51 is offline jimbo51  Australia
jimbo51's Avatar
Originally posted by giacomo_pagani
Uh... I'm referring to the R8 which is shown in the actual PDF on www.firstwatt.com
I downloaded it again a few days ago... What am I missing?
Giacomo
Looks like the earlier (11/08/06) version has snuck back up on www.firstwatt.com.
The latest version was referred to as R0 and dated 6/4/07
Old 15th May 2008, 09:57 PM   #2295
Send a message via MSN to giacomo_pagani
Now it would be very interesting to know which one is actually better... Maybe the fact that the old one has been brought back on site means something?
I have to freeze with my shopping, 'till I get an answer now. Thank you for pointing that out
Giacomo
Old 15th May 2008, 11:13 PM   #2296
Giacomo
OK, I searched and found that this last version is better, period (being recommended by Nelson, and being the one on Peter Daniel's boards).
And I'm lucky with parts, too (except for the 750 ohm resistor, but I'll stick with two 1.5 kohm in parallel).
Giacomo
Old 15th May 2008, 11:14 PM   #2297
vitalstates's Avatar
I am so glad that somebody agrees with me that the OLD one circuit has been brought back up.!
Please tell me that this is something to do with the firstwatt site going down and coming back up with OLD files......
Ed
Old 17th May 2008, 07:27 AM   #2298
mosfet1 is offline mosfet1  Italy
Can I change IRFP 240 with IRFP 044 in the f4 circuit without any changes or it's a bad idea?
Bc/Philips capacitors 22.000/40 volts maybe a good choice for power supply? (I've a good amount of these capacitors, but I don't know if they are really good for audio).
What's the power (safe value) for each channel transformer?
thanks a lot
Old 17th May 2008, 04:30 PM   #2299
The one and only
Nelson Pass's Avatar
I think it will work, yes.
Old 17th May 2008, 05:12 PM   #2300
As stated above, I am so impressed by the F4 that I want to see what is possible with a version without any compromises...I am looking for your experiences / opinions:
1. ON the 220uf on the Board: I have currently Silmic II, which should be one of the better ones I guess as recommended by Nelson. If I want to try Blackgates in this position:
- FK
- NX solo
- Two NX which are soldered in parallel, but with opposite direction, so that errors are canceled out (see http://www.thlaudio.com/bgcapitme.htm )
which version would you recommend in this position ?
2. On the resistors in general (I guess this is a Peter Daniel-Question):
- Caddock MK132 ?
- texascomponents.com: TX2352 or TX2575 ?
3. May I ask a maybe stupid question ? Why are the 0.47-resistory specified as the Panasonic 3W-Types ?
Why not simply use the MK132-Type of Caddock as well ? There goes 0.21 Volts over my 0.5-Version which mean basically 0.42 Amps. So, this would mean a heavy 0,21*0,42= 0,0882 Watt, right ? So why aren't we using here the best resistor possible as well ?
Looking forward for your thoughts.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
