#2121 | |
Sheet is written as *****
Not so much,.......if it says "ZM" in the corner. |
#2122 |
Funny guy's
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#2123 | ||
Thanks for the suggestions. How do you rework it to 4 x 15V? Is it to rewind it? I've thought about a variac/choke, and also triac control for the AC but decided to have less parts in line with the Zen philosophy. Also I'm not sure if using a "capacitor bridge? for a floating ground?" will work (i.e., 2 caps in series tied to 0 and 38V, tap in the middle for 0V...so I can have -19V 0V +19V... sorry I don't know the correct name for this circuit) My question still is will I blow something up with +-38V rails? Thanks. |
#2124 | |
Most likely you will fry the Jfets as these have a breakdown voltage of ~25V. If I know NP only a tiny bit, it is not by chance that the F4 uses a 23V rails..... |
#2125 | |
Great looking speakers
#2126 | |
![]() They are very heavy, as i filled the room beneth with drysand (The kind used to blow paint on walls off )Jesper.
#2127 | |
Looking forward to audition them ....and nice work BTW. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#2128 | |
naah...... fugly!
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#2129 | |
#2130 |
With a balanced F4, yes it will make just about anything sing at 23dB gain
Magura
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
