F4 power amplifier
F4 power amplifier
Old 3rd February 2008, 05:30 PM   #1971
Andrzej Sochon is offline Andrzej Sochon  Poland
Andrzej Sochon's Avatar
Originally posted by apassgear
Farads are good up to a point, depending on the amp bias ....I do bypass the amps PSU with some oiled polyprops cans on the 40 to 80 uf ...I also use these caps for lineamps some 25uf bypassed also with small film caps (0.1uf) with outstanding results. .......I suggest you try them and have your ears be the judge.
I add few capacitors to my f4 lineamps, see attached schematics. Capacitors at input are soldered directly to the jfet legs and input ground. 220uF capacitors at output are C5 and C6 on Peter Daniel board, according to his suggestion.
Overall results are very nice for my ears. javascript:smilie('')
wink
Best Regards,
a.
Old 3rd February 2008, 06:48 PM   #1972
cviller is offline cviller  Canada
cviller's Avatar
wink
Best Regards,
a.
Sorry for asking, but what is the reason for providing an ac path from out to signal in gnd? If you want to make global feedback wouldn't it be more obvious to apply it to the signal and not gnd?
Old 3rd February 2008, 07:44 PM   #1973
Blues is offline Blues  United States
Blues's Avatar
Additional +/- supply filtering of front and output stages...
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 3rd February 2008, 07:57 PM   #1974
Originally posted by cviller
what is the reason for providing an ac path from out to signal in gnd? ....
capacitors at output are not on the signal in gnd - Peter Daniel made on his amp board separate gnd point for C5 and C6 to be wired to PSU gnd...so there is no feedback loop.
a.
Old 3rd February 2008, 08:04 PM   #1975
a.
I put comments around GND points on the schematics, see the picture below
a.
Old 3rd February 2008, 08:04 PM   #1976
cviller's Avatar
I was not talking about the rail caps, but the 100u and 22n placed on the input.
Old 3rd February 2008, 08:07 PM   #1977
cviller's Avatar
Here is the path I'm talking about.
Old 3rd February 2008, 08:10 PM   #1978
Blues's Avatar
Same thing...+/- supply filters for the front end.
Old 3rd February 2008, 08:19 PM   #1979
I understand what you mean; but in my opinion 100u and 22n does not provide an ac path from out to signal in gnd. Capacitors added by me are between In GND and internal +/- DC sub-rails, creating additional filter.
a.
Old 3rd February 2008, 08:20 PM   #1980
cviller's Avatar
That only holds true to the old revision of F4, but this one has the output swing (simple voltage divider between the 1k resistors) at those points.
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
