F4 power amplifier
F4 power amplifier
Old 2nd December 2007, 09:37 AM   #1611
jameshillj is offline jameshillj  Australia
Carpenter,
it will sound better still when it gets really hot (+55*C)!
Old 2nd December 2007, 05:54 PM   #1612
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
F4 power amplifier
Originally posted by Babowana
Did you use all matched MOSFETs?
I matched N fets to N and I matched P to P. The P channel VAS test result is 0.18 volts apart from the N channel.
I also match (ohm wise with a multimeter) all resistors that have a mate.
I made no attempt to match jfets. I just asked them to be blessed with the loving energy of the "golden ears" spirit.
The amp does hit the 50 degree mark, but holds steady--in fact, I'd swear that the fets get cooler when the amp is playing music.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 2nd December 2007, 06:06 PM   #1613
Andrzej Sochon is offline Andrzej Sochon  Poland
Andrzej Sochon's Avatar
Default N to P matching
what about N to P fets matching, does it make sense or not for f4?
Andrzej
Old 2nd December 2007, 06:57 PM   #1614
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
I think that I sent you matched 170/74 ; P to N
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd December 2007, 07:06 PM   #1615
carpenter's Avatar
F4 power amplifier
Thanks, Choky. I forgot
Old 2nd December 2007, 07:08 PM   #1616
carpenter's Avatar
F4 power amplifier
Default Re: N to P matching
Andrzej
Not in my case. I'm using P channels that are 0.18 volts apart from the N channel and only have 1 mV offset drift after P2 correction.
Old 2nd December 2007, 07:08 PM   #1617
steenoe is offline steenoe  Denmark
steenoe's Avatar
Andrzej
You can match the N's to the P's if you like, the advantage will be (probably!!) less offset at the output. In any case, it will never hurt, whatsoever.........
Old 2nd December 2007, 07:26 PM   #1618
carpenter's Avatar
F4 power amplifier
A couple of pic from my test bench (note the TO-220 fet pkg):
Old 2nd December 2007, 07:27 PM   #1619
carpenter's Avatar
F4 power amplifier
Here's a Wakefield 392-300AG heatsink given to me from a fellow carpenter. He had no idea what it was, but thought I might be able to put it to good use.
I purchased a mate for it at a cost of $160.00. This will be my first F4. For the rest of the F4s, I'm going to play with water cooling.
Caps in PS are 47,000uF each.
Old 2nd December 2007, 07:33 PM   #1620
Default Re: Re: N to P matching
0.18 volts you got per accident or you ordered or choosed or selected such an exact 0.18 V combination of P and N channel? Could it be 0.15 or 0.21 Volts for instance? (As far I understand 0.15 is better).
I try to understand what do I need to look/ask while ordering the set of IRFP's for my ballanced f4, two channels. In other words what is the most important: N to N matching (4xNNN in my case) and separately P to P matching (4xPPP) or matching all together what seams me to the best but probably not available for me (4xNNN AND 4xPPP). I see the IRFP240 and IRFP9240 curves are different. Sorry my language...-
a.
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
