F4 power amplifier - Page 16 - diyAudio
Old 27th March 2007, 07:01 PM   #151
EUVL is offline EUVL  Europe
If you need 9.78V (say 10V), you would want to have
R9+T1 = 22k/3
Read datasheet for TL431.
Patrick
Old 27th March 2007, 07:35 PM   #152
cviller is offline cviller  Canada
cviller's Avatar
Reading is good. Did you know that you can make basically any circuit with those tl431s, currents source, voltage source, comparator, ohmmeter and phono amp - crazy little thing in my amp.
I'll try lowering it instead then...
Old 27th March 2007, 08:19 PM   #153
There are many many ways to generate the bias voltage.
TL431 is one. If you look at my schematics for Follower with gain a few post earlier, I just use resistors with current sources.
Patrick
Old 27th March 2007, 08:20 PM   #154
cviller's Avatar
I put in some 5.49k's I had in the drawer and it worked perfectly. Now I can raise the current to almost 2A through each transistor but I have set the voltage across sources resistors to 300mA and then I'll listen some more and see how hot the sink gets.
I must say it sounds great. My preamp is too weak and shitty to show me the full potential of this buffer amp, but I'm one happy builder!!!
Thanks Patrick for helping me with the current and a huge thank you to Papa!!!
Old 28th March 2007, 05:28 AM   #155
steenoe is offline steenoe  Denmark
steenoe's Avatar
Congrats, cviller. Nice to see a finished and working F4 Really nice job on the boards. You are quite a wizzard. Mine is nearly finished and I am looking forward to try it with different preamps/speakers. Hopefully this weekend.
Steen
Old 28th March 2007, 12:32 PM   #156
mpmarino's Avatar
Congrats, cviller
...I am quite surprised! I had my money on your being first Steen! Are you feeling OK?
yeah. Congrats, cviller!
Crazy Yankee.
Old 28th March 2007, 12:36 PM   #157
cviller's Avatar
There is a really good explanation...
Although I have many weak links in my sound-system, I can tell you it sounds great!! Have you started populating your boards?
Old 28th March 2007, 02:09 PM   #158
mpmarino's Avatar
Yes,
The boards are fully populated with the exception of the pots. There is little time available in the near future so I guess I'll get there someday.
I always insist on having a almost completed chassis before I turn an amp on. I'll let you know how it sounds around ... November maybe!
Crazy Yankee.
Old 28th March 2007, 03:39 PM   #159
doggy is offline doggy  Canada
doggy's Avatar
Default A few questions
The f4 will be the next amp for me to build. I can follow schematics and get it done but I confess I am no electronics whizz but am interested to learn more.
A few questions please:
Setting bias, what is the voltage range? and should it be positive or can it be negative voltage measured at the outputs with the inputs shorted.
How do you measure amperage output of the amplifier?
Is there a good article on class A amplifier circuits?
Old 28th March 2007, 04:17 PM   #160
Unlike mpmarino, I have no high standards about firing up 15 pieces strung together by wire so I guess I'll be done before you (I hope)
My boards are populated and I started drilling the heatsinks, but ran into a problem with lack of any wiggle room, so I'm going to use bars of alu to hold the fets to the heatsink instead of screwing them down individually.
With any luck (and wife permitting), I should be making music by ... say mid-April
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
