#1541 | |
Banned
No magic smoke, we don't want that. |
#1542 |
Paper mache horn fabricator
Dave, are you using proper anti-static techniques when handling your FETs?
It's freezing cold, where you're located, and that means static electricity abounds. Just checking all the possibilities.....
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#1543 | |
diyAudio Editor
Magura was one of its midwives but he probably can't give you measurement info unfortunately.. |
#1544 | |
Darn...
#1545 | |
Complementary wise, Mosfets are less well matching than Bipolars, and vertical Mosfets are worse than lateral devices. The reason why some prefer quasi-complementary and Mr Hansen has to go the fully balanced symmetrical way to skip global NFB.
Not so much,.......if it says "ZM" in the corner. |
#1546 |
About the static, I am aware and do my best. I make sure to touch ground before picking anything up. I would guess that if I had taken something out with static that it would not be passing a signal and making music. And the identical behavior between the two channels signals to me, in my limited experience, that everything is functioning properly, just that there is a mismatch or imbalance somewhere.
The diodes are correct. 1N4736. Bias process is as described. Center P2, set P1 to zero. Power it up. Bring P1 up to adjust bias. Voltage across bias resistors to 200 mV per manual. Then adjust the DC offset with P2, measuring between ground and + out. So far the smoke is still in. I hope to keep it that way. |
#1547 | |
It's when you bring the bias measurement up to 200mV that the offset swings to 30 volts, yes? How far can you adjust the offset with P2? Edit: how about a close-up pic of your pcb?
#1548 |
The 30 V DC offset is with P2 turned to zero. When I start with it in the middle the offset in higher.
About the picture.... I intentionally left the leads long on all my changed parts. They are RS parts and I plan to change them out with Vishay's once I get it running and the values dialed in. Keeping the questionable components high off the boards makes them a whole lot easier to work with. |
#1549 |
Another pic
#1550 | |
Banned
Pots are in backwards
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
