F4 power amplifier - Page 154 - diyAudio
Old 25th November 2007, 01:20 AM   #1531
DaveM is offline DaveM  United States
DaveM's Avatar
So, the new parts are in and the story is the same. 155 mV max bias with no DC offset. I'm stumped, but not giving up. The mosfest I am using were matched by Peter Daniel. Now unless I somehow shuffled them, I think they should be ok.
Winter is coming..... Ha!! We've had snow twice. We actually had snow and then the last of the trees in our yard dropped the leaves. I spent part of today raking frozen wet leaves.
I am going to work on walls before that bass horn, yet I may end up there someday.
Old 25th November 2007, 01:35 AM   #1532
Paper mache horn fabricator
carpenter's Avatar
How about something like this?
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 25th November 2007, 01:37 AM   #1533
carpenter's Avatar
This is with 8k on R9?, try going down a smidgen, like 7k. You're so close!
Old 25th November 2007, 01:53 AM   #1534
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
I'm another of the winter F4 Improvement Society. Also rebuilding to a new system, F4 based. I DO have an advantage as my F4's have been operational- I just need to strip them down and rebuild them to be reliable. Then I have actually just ordered a kit for a Pumpkin pre. Finally a balanced Twisted Pear DAC and my old Baszilla's ....and time for a break - I hope before winter is over....
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 25th November 2007, 02:42 AM   #1535
carpenter's Avatar
Hi Variac,
Which F4 version do you own? Maybe Dave can compare some setting with you?
Old 25th November 2007, 02:55 AM   #1536
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
My F4 amp is for sale, nothing wrong with it, but i don't need it. I hve 4 aleph's Any one want a 90% completed amp ? Needs face plate and rear plate and top.
Old 25th November 2007, 03:17 AM   #1537
DaveM's Avatar
So, I believe that we are barking up the wrong tree with changes to R9. Every change I make I am able to dial right back to 160 mV bias and no DC offset with P2 at zero.
Is there any harm in dropping R22 down so that I have more bias adjustment?
Old 25th November 2007, 03:37 AM   #1538
BDP is offline BDP  United States
By any chance did you measure each source resistors voltage?
Old 25th November 2007, 03:39 AM   #1539
DaveM's Avatar
Yes I did. There is slight variation, but they are very close. +/-1 mV
Old 25th November 2007, 04:07 AM   #1540
carpenter's Avatar
Sure, I'd take a chance, but make a subtle change. If things work in your favor, continue--less chance of letting out the magic smoke.
Also, describe your P1/P2 adjustment process, please.
You're using 1N4736 diodes?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
