F4 power amplifier
F4 power amplifier
Old 6th September 2007, 09:44 AM   #1131
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Originally posted by lykkedk
Posted by R.K.Rønningstad :
Might be a quick sollution with an audio-transformer, how does that work ??? Just for temporary use...
Jesper.
Have a look here http://www.lundahl.se/pdfs/datash/5402.pdf
The Lundahl LL5402 is intended for unbalanced drive, e.g. a single opamp as shown, or probably more or less any decent preamplifier. But read carefully through the data sheet.
Old 6th September 2007, 10:28 AM   #1132
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 power amplifier
Originally posted by R-K Rønningstad
Yes, I do, or else I would not have proposed it
That infinite BlowTorch (BT) reverse engineering thread has revealed it has balanced outputs and runs off cirka +/- 24 Volt rails.
So me thinks the hot pin on ts XLR output swings to almost +24 Volts while the cold XLR pin swings down to -24 Volts simultaneously, so between hot and cold more than 40 Volts of undistorted music appears!!!
Remember the hot pin of the XLR is connected to one F4 input and the cold one to the other F4 input. So these swings between the 24 Volts rails of the BT. The F4 runs off 22 Volt rails, so this should be a nice fit. The BT should possibly be able to even overload the F4.
So put the BT and the F4 in the same chassis boyz, and get the worlds best integrated amp!
RK
naah......
is better
(anyway- who needs that UGSish (Pass's)/BT/Borbely simplicity ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 6th September 2007, 12:03 PM   #1133
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Then start selling veggie boards, ya pric.
The day ya sell plumpy boards is the day me builds F4s
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 6th September 2007, 12:15 PM   #1134
Magura is offline Magura  Denmark
Magura's Avatar
That's easy for you to say Jaccolina. You will most likely be in a retirement home when it happens, and they won't let you play with that kind of stuff
Magura
EDIT: Not when that happens....IF that should happen!
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th September 2007, 05:37 PM   #1135
Zen Mod's Avatar
F4 power amplifier
Jaccolina and Magurina are both .............. what's proper word..........
naah.......
greedy boyz ;
I promised for Burning (pre)Amp expo ..
Old 6th September 2007, 06:02 PM   #1136
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
F4 power amplifier
Yup, if you wanna hear Lil' Punkin' pre with the mighty F4's then the West coast USA BURNING AMP is the place to do it.. Oct 21, 2007
Variac
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 6th September 2007, 08:57 PM   #1137
Zen Mod's Avatar
F4 power amplifier
Originally posted by Variac
Yup, if you wanna hear Lil' Punkin' pre with the mighty F4's then the West coast USA BURNING AMP is the place to do it.. Oct 20, 2007
Variac
it will not be surprise to me if Papa bring ya all some nasty Fx ;
not F4
at least that's what little birdie whispers to me
Old 6th September 2007, 09:14 PM   #1138
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Default Variac,
Since we live close to each other, where is "Burning AMP 2007"?
C
Old 6th September 2007, 09:21 PM   #1139
Zen Mod's Avatar
F4 power amplifier
Default Re: Variac,
C
what a question!!??
of course- where da is.........
http://www.diyaudio.com/forums/showt...hreadid=106844
Old 6th September 2007, 09:49 PM   #1140
diyAudio Editor
Variac's Avatar
F4 power amplifier
Chris,
It is now at Ft. Mason, in San Francisco, right on the bay.. right where Robot Wars and other tech-geek events happen-but off to the side in a separate building.
Unfortunately, it will cost a lot to rent , so we would appreciate people contacting AR2 and telling him that you will make it. AND please get like minded friends to attend..and sign up..
Magura will be coming in person!!
Zen Mod by proxy -he's sending a Pumpkin preamp.
SY is finishing his tube preamp with balanced outs for the F4
I'm desperately working on my pair of F4's
So it's going to be an F4 Fest!!! In fact, we may need more..
Variac
F4 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
