Old 4th September 2007, 11:37 AM   #1111
Studley is offline Studley  United Kingdom
Default Application question
In the user manual it says the F4 will work well with a preamp or other line source (assuming you have efficient speakers).
I'm wondering whether this would work: My CDP (ouput 2v) into a passive volume control (eg TVC or Lightspeed) into F4 driving Bastani Atlas open baffles (sensitivity 100db / 16 ohm load). A couple of watts is apparently enough to drive these OBs.
If necessary maybe I could insert a Burson Buffer in the chain as they add 6db.
Old 4th September 2007, 11:42 AM   #1112
R-K Rønningstad's Avatar
Default Re: Application question
As the F4 is unity gain, your 2 Volts (peak) will give 1/8 Watt RMS into your 16 ohms speaker. (P =U^2/2*R)
RK
Old 4th September 2007, 11:56 AM   #1113
RK
OK thanks (for showing my ignorance )
Old 4th September 2007, 12:04 PM   #1114
spencer is offline spencer  Hong Kong
Send a message via MSN to spencer Send a message via Skype™ to spencer
I have finished my second F4 amp today. Distortions as below:
Left: 0.016% @ 1W and 0.03% @5W
Right: 0.017% @ 1W and 0.035% @ 5W
All 1kHz, 8.2 ohm load. Bias 1.5A each channel.
I used it as balance mode and the bass is much firm and strong than single unit guess due to higher power and match up with my Bal DAC. I would say it is another step better!
Thanks NP for sharing this wonderful design.
Spencer
Old 4th September 2007, 02:24 PM   #1115
protos is offline protos  Greece
protos's Avatar
Originally posted by lykkedk
This was from a very old thread, posted by master Pass himself... I guess it's allright that they grow hot!
Jesper.
Don´t forget that is amps at the primary not the total bias+losses of the amp itself at the secondary.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´
Morgan Jones, Building Valve Amplifiers.
Old 4th September 2007, 02:33 PM   #1116
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its amazing how the old and straightforward buffer concept is celebrated worldwide, only after Nelson put it forward again. It seems that audio world is not needing super circuits, it simply needs concept lead.
Bravo Nelson.
Old 4th September 2007, 02:46 PM   #1117
Great job Spencer, very attractive babies, congratulations !
Could you let us know about your enclosures, seems to be galaxy...
Thanks for the answer.
Very good looking F4 pieces, I hope to design mine as successfully as yours.
Old 4th September 2007, 03:04 PM   #1118
The enclosure has two version but my final version is 200mm height x 400mm deep x 350mm wide because I manage to find a supplier of heatsink of 400mm wide x 50mm thick in China. I design the case with all drawings and ask a metal shop to custom made for me for a total cost about US$200/ea. Face plate is 10mm wider/taller with 10mm thick and all polished and anodized per my spec. All the plates and heat sink are connected together with 12 pieces "L" sharp bar with either holes or tapped holes. Total weight of the case is 13kg net and completed amp is over 20kg.
With this size, the temperature rise is about 18 deg C max.
Old 4th September 2007, 06:19 PM   #1119
The one and only
Nelson Pass's Avatar
Well, it just goes to show that this is a fashion industry.
Old 4th September 2007, 07:06 PM   #1120
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Or it's because sometimes a new need arises which can be addressed by an old idea...
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
raneypdx
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.12725 seconds (69.35% PHP - 30.65% MySQL) with 11 queries
