#1061 |
The 35A will probably be the If rating of the bridge, the slow blow fuse is on the primary of the transformer were the current is much lower than on the secondary the maximum the bridge will see is a function of the output impedance of the secondary winding of the transformer and the // combination of the power supply CRC section and the actual load
(amplifier). In other words much higher than 2.5 A |
#1062 | |
I guess all I need is the working voltage for the 220uF capacitors. Does anyone know what the minimum would be here? |
#1063 | |
#1064 |
Thanks guys for the links to shops for big heatsinks in Europe.
Jaac: pretty impressive chassis you are building there! Mighty tranformer lying left to the heatsink. Your heatsinks will stand up to the task of converting all that current to heat you think? |
#1065 | |
The amp that you see on the photo's is the finished aleph 5 and having 40 volt dc rails drawing 2 amps thats 160 watts in idle to dissipate by the heat sinks. They get hot, not hotter then a X150.5. tomorrow i will measure the temp of my heat sinks and also of a pair of XA100 to compare with. For the F4 i think the sinks will do the job but i also have some other sinks here at my house and they are bigger and they need some cutting i think to use them for an amp. |
#1066 | |
Banned
I think you can build a nice x1000 with that piece Jase |
#1067 | |
#1068 |
Nelson
I've ordered a pair of the Plitron 300VA 18v trafos through the group buy. These have the"type 7" primaries which are suitable for 115v or 230v. I'm in the UK and I've just been advised that our mains is in fact 240v +/- 6%. Plitron tell me that these trafos can handle up to 230 +10%, which means they might be just about be ok for worst case of 240v+6%. Do you use their type 7 trafos in your commercial offerings that are bound for the UK, or do use their type 5 which are configurable for 240v? (Hoping for some additional comfort from you here!) thanks Ian |
#1069 |
The one and only
I use the 240's, but I don't think you should worry, as Plitron
is very conservative, and besides that, we put a Thermistor in series with the primary.
#1070 |
Thanks Nelson.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
