F4 power amplifier - Page 100 - diyAudio
Old 2nd August 2007, 06:25 PM   #991
Default F1 vs F2 vs F3 vs F4
This is the post comparing the F1-F2-F3-F4 amps:
http://www.diyaudio.com/forums/showt...46#post1152546
The F4 sounds like a cross between the F1 and the F3. Cleaner than the F2, a touch of sweetness, but the truth is still front and center. I have not heard this amp in my system (yet), so my thoughts about this may change. It is a very exciting product.
Old 2nd August 2007, 06:29 PM   #992
Default F1 vs F4 Bass
I use the F1 for basses (20hz - 630hz). I'm happy (very) with it only that in some instances in somehow lacks the power for the woofer. I'm considering changing for the F4. Since you have listened both amps, what are the main differences between both F1 & F4 listening wise ?
Hi Nicola:
An impossible question. Because the F1 is a current source, and the F4 is a voltage source, a bass system designed for the F1 would not work well with the F4, and one that works well with the F4 would not work will with the F1.
That being said, both have worked very well in bass note reproduction when used with an appropriate speaker. The F1, because of its lower power, would work best with hi-efficiency woofers. If you are having a power shortage, I would certainly consider using the F4 in bridged mode where you can get a up to 100 watts of power.
Jon Ver Halen
Lowther-America
Old 6th August 2007, 11:48 AM   #993
spencer is offline spencer  Singapore
Send a message via MSN to spencer Send a message via Skype™ to spencer
F4 going to finish and now under bias adjust.....
Old 6th August 2007, 11:51 AM   #994
Bias total 1.5A per channel and take very long time to become stable. DC offset below 5mV for all channel. Supply voltege at +22/-22V by using two 18Vx2 250VA transformers.
Old 6th August 2007, 01:18 PM   #995
apassgear's Avatar
Good to see another F4 coming to life...very nice work Spencer
Those PCB are from PD?
Lets hear your first impressions of sound
Old 6th August 2007, 06:15 PM   #996
Default Re: F1 vs F4 Bass
[QUOTE]Originally posted by twitchie
[B]This is the post comparing the F1-F2-F3-F4 amps:
Originally posted by Jon Ver Halen
Hi Nicola:
Many thanks for the comment. This is exactly what i'm trying to find out. The woofers are around 99db, but if I compare the F1 with a classical voltage 20 or 40w class A amps, with some instruments it seems to lack the headroom, like there is a more limited power available especially with chords / piano / cello - where the instrument is fast in its attack. But on the other side none of the voltage amps have this control... so as you wrote it is like strawberry or vanila... Kind regards
Specs from woofer are
SPL: 99dB enclosed in box reaches 105db 1m / 1w +- 2bd
Fc: 43 Hz (Qes: 0,34, Qts: 0,33, Qms: 10,5, VAS: 231, Re: 4,8 Ohm ,EPB: 126,5)
Old 7th August 2007, 02:19 PM   #997
vizion is offline vizion  United States
Can the F4 be driven with 2.8vrms from a source unit ?
Old 7th August 2007, 02:22 PM   #998
yeah I was wondering something of the same sort will a preamp with an 18.5 db gain be enough for the F4?
Old 7th August 2007, 02:41 PM   #999
mpmarino's Avatar
Crazy Yankee.
Old 7th August 2007, 02:57 PM   #1000
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by mpmarino
If you don't answer the boys....you can't have any cookies
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
