Old 26th February 2007, 12:36 PM   #1
Stefanoo's Avatar
Default Aleph P1.7 "the design starts here"
Hope somebody will be interested to make this Nelson Pass 's preamplifier.
The opinion on the sound'quality, in comparison with the model L, are in disagreement.
I read that sombody preferes the P version sombody else the L version.
Accordingly to Nelson, the P version, would offer a better performances in noise terms and in dynicamc.
Anyways i finally decided to start to build this version but without the remote control, the only preamplifier.
I have to thank first Nelson Pass that allows us to use his projects to have fun and build something that actually sounds good.
Second i have to thank the guys here on the forum that were willing to share the service manual of the preamp and alwais willing to be supportive.
Anyways....i hope that somebody will like the idea of building this pre "with me" and work this out with me.
Anyways......
Here the first results that i got from the simulations ... i have some doubts..
Best,
Stefano
Stefano
Old 26th February 2007, 12:37 PM   #2
Stefanoo's Avatar
the power supply simulation.
In green the output and in red the output from the 2 capacitors.
This result shows that the rising time is about 12seconds, as it can be seen.
Is it not too much...is there anything wrong with this result?
is this fact an issue?
Stefano
Old 26th February 2007, 12:39 PM   #3
Stefanoo's Avatar
Now the simulations on the main board.
I have big problem to figure this out and i'll explain why.
On the service manual, in the main schematic, the connection are not marked with a point, as it should be, and so it's not so easy to understand if, when a net crosses another net, if actually it connects with it or not.
So, for instance, the input (i'm now referring to the inverting input, but everything is mirroarably to the not inverting input) would seem to go solely to the 10k input resistor R6.
But in this configuration i obtained, by visualizing on pspice, wrong output...at least what it looked to me.
So i had to connect that net that crosses the input and connects R61 and R69 to the input.
With this configuration i obtained results that i will post and that at least make sense to me.
Please, tell me if i'm doing wrong by connecting the input to R69 and R61.
Stefano
Old 26th February 2007, 12:40 PM   #4
Stefanoo's Avatar
This first simulation involves the output potentiometer on the main board.
I made a parametric simulation in order to check the value of the output for the following values of the potentiometer:
61.9, 249 and 8.6K.
The input, as it can be seen, is a 4V pk-pk sinusoid.
The output is around 4mV for 8.6k.
Is it normal that have a so small output swing compared with the input?
shouldn't be the output signal bigger than the input?
(output almoust 1000times smaller than the input)
Moreover, on te original schematic there is the 2K trimmer with the "rightgain" label.
When i try to vary its value, i don't obtain any variation on the output swing signal.
Is it normal?
Stefano
Old 26th February 2007, 12:44 PM   #5
Stefanoo's Avatar
I simulate the circuit for different values of the input.
I obtained distortion for the inpunt signal over this range:
up 7volt Pk-Pk and down to 800mV pk-to-pk
(as it can be seen on theattached pictures).
Is it normal that the preamplifier already distorces for an input of 800mV?
How much is suppose to be the input signal range and the output swing?
Stefano
Old 26th February 2007, 12:46 PM   #6
Stefanoo's Avatar
this is the output for input of 8V pkpk
Stefano
Old 26th February 2007, 12:48 PM   #7
Stefanoo's Avatar
and this is the output for 1Vpk-pk (so actually the lower extent is higher than 800mV)
Stefano
Old 26th February 2007, 05:30 PM   #8
Peppe is offline Peppe  Italy
Hi, look at point number 5 at the link:
http://www.diyaudio.com/forums/showt...22#post1143122
Maybe can help you
Old 26th February 2007, 07:57 PM   #9
Stefanoo's Avatar
Thanks for the link, but it referes to the Aleph3 's schematic , but it's good to know that i wasn't the only one have a problem with the connections on the schematic, since they are not marked off.
Anyways, I hope somebodyelse, also, will take part at prject and maybe will help me out with this issues.
Best,
Stefano.
Stefano
Old 26th February 2007, 08:03 PM   #10
analog_sa's Avatar
You really need help with this?! Easy with the simulators, you may hurt yourself
Seeking advice on "Circlotron" cross-coupled feedback OTL design arteitle Tubes / Valves 8 5th March 2010 09:55 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Aleph-X smaal EU "small-parts" groupbuy Sander Group Buys 3 3rd December 2008 11:48 AM
Aleph P1.7 "the design starts here" Stefanoo Solid State 9 26th February 2007 11:20 PM
Aleph "L" Stepped attenuator on the input or the output? Mark A. Gulbrandsen Pass Labs 6 13th March 2003 12:21 AM
Page generated in 0.11531 seconds (79.51% PHP - 20.49% MySQL) with 11 queries
