Old 26th February 2007, 01:17 PM   #1
FYC is offline FYC  Hong Kong
Default please help to clarify the coding
Sorry may be I am asking something well understood already.
Nevertheless, I am preparing to build a PLH amp. Reading the schematics, I found the resistor value a bit confusing.
I see both 220 and 221. My first interpretation is that the last digit refer to the number of zeros, so "220" = 22 ohms, and "221" = 220 ohms. But this will make the code "392" equal to 3900 ohms, which I expect it be a 392 ohm if I want to set the bias of the phase splitter current to the correct value.
So apparently the last digit does not carry any special meaning but "220" IS 220 ohms while "221" IS 221 ohms. But then why not standardize to 220 ohms?
Please help me to understand this and forgive me if this issue was well explained before.
Old 26th February 2007, 01:37 PM   #2
medum is offline medum  Denmark
medum's Avatar
Default Re: please help to clarify the coding
220 ohm are standard in normal 5% resistors
221 ohm are standard in 1% resistors
try to google "resistors E24" and "resistors E96"
numbers refer to steps between values.
Old 26th February 2007, 01:50 PM   #3
Thanks for quick and clear answer.
The Zero Positioning Coding;more processor power for Class D? The golden mean Class D 7 10th August 2006 01:15 PM
coding your own PCM to PWM converter? jwagnerhki Class D 2 15th November 2005 10:06 PM
Page generated in 0.07982 seconds (69.81% PHP - 30.19% MySQL) with 10 queries
