The Unvailing of the ???? at the CES
Old 22nd January 2003, 09:10 PM   #101
cyclotronguy is offline cyclotronguy  United States
The SACD digital front end was graciously provided by Axiss the US importer for Accuphase…. A truly spectacular machine.
Kent
Pass Labs
Old 22nd January 2003, 09:31 PM   #102
Pan is offline Pan  Sweden
"I don't know about the Philips mid you mentioned, but I cannot see the 15" bass driver being a Volt, somehow.
The larger Volt units like this usually (always?) have the front-located 'spider' arrangement which you would readily see on the Rushmere pics. "
Well in such case I was waaay out of target with my "hip shot", or is it shoot?
/Lucky Luke
Old 27th January 2003, 11:12 AM   #103
Wes Marquenie is offline Wes Marquenie  Netherlands
I was wondering how hot the rushmore runs.... It does not look like there is that much heatsink surface to dispensate 300 Watts.
Old 27th January 2003, 01:08 PM   #104
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
If I recall correctly, the heatsinks run the entire length (top to bottom) of the back of the rushmore.
Old 27th January 2003, 01:35 PM   #105
That is correct. So the heatsink has a height of 50" and a width of approximately 12". But just half of that width is covered with fins.
I have just finished a aleph 5 and for two channels (300 Watts) I use a heatsink of 12"*28"*3,25", which I think is comparable to the ruchmores. If it is turned on and doing (almost) nothing for about a hour, it gets pretty hot, bearly touchable.
Old 27th January 2003, 01:49 PM   #106
Warp Engineer
On Holiday
AudioFreak's Avatar
'bearly touchable' is pretty much exactly in the region where we generally operate these kind of amps. I dont believe that the rushmore is any exception to this.
The Unvailing of the ???? at the CESHide this!Advertise here!
