Old 25th February 2007, 05:59 AM   #1
Tyimo is offline Tyimo  Hungary
Default Diode bridge as loop breaker question
Hi!
After a serious grunding noise problem with a tubepreamp and the SEWA mosfet follower amp I was re-reading all my articles about earthing and I found something mistakable thing with the diode bridge coupling.
Mr. Pass wrote in the ZV4 docs:
Note in Figure 6 that we have chosen to isolate
the two channels through a rectifier bridge to ground, with each
channel’s ground appearing on one of the AC legs of the bridge.
As it is in the attached image.
Mr. Rod Elliot wrote:
Note the way the bridge is wired, with the two AC terminals shorted, and the two DC terminals shorted. Other connection possibilities are dangerous, and must be avoided.
as it is in the next attached image.
Now I have only one question:
How should I connect the diode bridge to the circuit grund?
DC legs to Earth - AC legs to the circuit? Nelson Pass
AC legs to Earth - DC legs to the circuit? Rod Elliot
So, Who has true?????????????????????????????
Greets:
Tyimo
Old 25th February 2007, 06:00 AM   #2
Here is Rod Elliots version:
Old 25th February 2007, 06:35 AM   #3
Formerly "jh6you". R.I.P.
Babowana's Avatar
Default Re: Diode bridge as loop breaker question
Both.
Old 25th February 2007, 06:47 AM   #4
Hi Babowana!
Than why Rod Elliot wrote:
Tyimo
Old 25th February 2007, 07:09 AM   #5
Babowana's Avatar
When he wrote that, he was unsure of himself . . . ?
I hope the attached sketches show the understanding.
The horizontal flip is always direction-free symmetry.
Either end of (+/-) or (~/~) could go the gnd.
Old 25th February 2007, 07:52 AM   #6
Nixie is offline Nixie  Canada
Banned
For a ground loop breaker, besides the diodes you should put a 5 to 20 ohm resistor in parallel, as well as a small cap as HF bypass (0.1-1 uf). Make sure the diodes are rated at sufficient current so that in a fault situation the fuse on the hot mains line blows!
Old 25th February 2007, 07:58 AM   #7
Babowana's Avatar
Why?
Old 25th February 2007, 08:05 AM   #8
Banned
In most ground loop breakers I've seen, the diodes are there as protection in case of fault where the resistor would just burn out. It's the resistor that's doing the ground lifting--you just need sufficiently different resistances on each of the legs of the ground loop. If you just have diodes, the circuit ground is floating within the one diode drop from earth, with no connection to earth; with a low value resistor, I find it still breaks ground loops, but the circuit tends to stay closer to eart. The bypass capacitor allows earth to sink HF interference. With the scope I see less RF on the circuit ground when the cap is added.
Old 25th February 2007, 09:04 AM   #9
Hi Nixie!
Thanks! Yes, I know. Rod Elliot wrote the same. Most of time a simple diode bridge (35A) or a thermistor (10R/5W) was enough for me.
Greets:
Tyimo
Old 25th February 2007, 09:14 AM   #10
Banned
The diodes are there for safety reasons. Do not omit them, and again, make sure their current rating exceeds the main fuse sufficiently.
Stupid Bridge/Diode Question richie00boy Parts 36 13th March 2006 07:55 AM
How save is a ground loop breaker? k.junold Solid State 0 14th October 2004 07:47 AM
ground loop breaker biff584 Solid State 3 27th August 2003 12:20 PM
Page generated in 0.11082 seconds (78.95% PHP - 21.05% MySQL) with 11 queries
