just to clarify, which of the pass amp is a "current" amp and which a "voltage", as i want an amp playing with 2 way and i dont want series xover (maybe aleph?)?
thanks, Patrick |
#2 |
The Aleph amps are voltage amplifiers, as is the Aleph-X, the A-75, the Zen variants...basically, you have to go to the First Watt amps to find a current amp.
Grey |
#3 |
Anyone correct me but I believe only F1 and F2 are current source amps.
/Hugo |
#4 |
hmm, i just finished the original zen, except the mounting of the boards, but case and everything, and i didnt finish it, because i got in my mind(think i read it somewqhere....) that it's a "current" amp and i cant drive 2 way as well as with an voltage amp. and as i dont want to do a case 2 times, and the parts havnt really been expensive i asked =|
so maybe i'll finish it or just go for some aleph IF it's only the Firstwatts being current amps. would be great news thanks & regards |
#5 |
what aleph would you go for with a budged of 150-200€(i need about 40-50w@8)? (got the sinks &case,plugs etc.) as matching fets where one costs 5€(i.e. irfp044) could get exp :|
| schematic variation and sim results of Pass "X" series US pat 5376899 | tiefbassuebertr | Pass Labs | 13 | 30th July 2009 08:33 PM |
| Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 6th September 2008 11:35 PM |
| power supply schematic with a 6080 used as a "pass tube" | jarthel | Tubes / Valves | 1 | 27th May 2006 03:41 PM |
| "Which linearity" is the best? Current, Voltage, Power? | sfx | Solid State | 6 | 25th May 2004 02:50 AM |
| Page generated in 0.07341 seconds (72.66% PHP - 27.34% MySQL) with 10 queries |
