same said:Hi,
there some troubles using 1/4W carbon resistors instead metal film resistor in A30?
If is only a problem of tollerance, I can selected the resistor to find the exact value.
giorgio
if you like it-just go for it
in range of 5%,even tolerance isn't a problem
same said:1/4W carbon resistors
The carbon R is good for the vintage.
I have also heard that the carbon R contains more noise.
wuffwaff said:
You can use 1/8 watt metall film in most places and they will fit quite nicely.
William
This is not a bad idea. I have studied a bit the circuit, seem to me that all resistors over 1K works under 1/8 W power.
A bit critical, maybe, are the two 1.5K resistors (R17,R18)
Is that correct?
giorgio
- carbon resistors for A30
