Hi everyone,
now i have finished my first DIY-Amp, an Aleph3.. I am very pleased with the results, the sound is simply marvellous! Here are some details 500 VA 2x18V transformer, 6x47000uF Caps bypased with Wima MKP10 1uF, Mcap Supreme (induciotnfree) 0.1uF and a 10nF KP (an addvice from Klaus, i am still testing..), Epcos 5Ohm NTC for limiting inrush current, MBR3060PT double diodes, mounted on an 2 K/W heatsink, two Fisher SK56 heatsinks (0.35K/W), the enclosure is made of 3mm (about 1/8") copper. The amp weights 18kG (about 40 lb) The front is made of 16mm (3/5") MDF wood with Madrona-veneer. The amp has got a Dc-offset of 20mV resp 30mV on the other channel. The heatsinks get to a temperature of 55 degrees (room-temp is about 23 degrees). Oh, I don´t have acces to my webspace right now, so i have to attach the pics as a zip-file... regards, smithers |
#2 |
Here is the zip file..
#3 |
Very Nice,
One question, your power-supply is for both channels? (1 transformer, 1 bridge, 1 bank of caps) The answer is yes |
#4 |
Oh, i forgot the PCB ;-)
Here it is: |
#5 | |
2. Why 3 differant values? 3. What type of caps works best for this purpose?
"Be carefull who's advice you buy, but be patient with those who supply it." From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen) |
#6 | |
i just made a copy of the cascade that Klaus is using in his Aleph4, have a look: Small Aleph 4 power block... I haven`t yet tried other values or other combinations myself so i am not able to verify his observations at the moment, i am still testing,but i suppose that everyone has to make his own tests to find out what type of cascade fits to his amp best. Regards, smithers |
#7 |
I've got a problem.
I've horrible difficulties to get some thermistances in France. I don't want to try my aleph3 without it. So we have the CL-60 and the Epcos 5Ohm NTC. Do you know some other parts for this work?
Miles Teg Le rugissement du puceron aphone |
#8 |
You can get thermistors in any PC powersupply, they aint always 5ohm - some 12 or 15ohm, but still work just as well. I use 2 of these in serie on my Aleph30, from 0volt to earth ground and another 1 just after my AC line fuse and it works perfect, every time. Just take note that they do get warm when passing current, so if you switch off, wait for it to 1st cool down before switching on again, other wise fuse will go pop.
#9 | |
#10 |
Other thing else. Because my English isn't very well
So your advice is to put a slow blow fuse in remplacement of the thermistor. Just a temp solution of course.
| Another GC is born! | mantisory | Chip Amps | 10 | 6th July 2006 03:35 PM |
| One more DIY TT is born | livemusic | Analogue Source | 18 | 20th December 2005 09:44 AM |
| Newbie Just Born... | aston_lm | Introductions | 2 | 18th July 2005 09:38 AM |
| New DAC born | mdlover | Digital Source | 8 | 10th July 2003 09:20 AM |
| New clone born | king30 | Chip Amps | 5 | 11th March 2003 03:35 AM |
| Page generated in 0.12632 seconds (81.53% PHP - 18.47% MySQL) with 11 queries |
