Pearl: replace zener D1 with voltage divider?
Old 21st February 2007, 01:54 PM   #11
h_a is offline h_a  Europe
h_a's Avatar
Great! Thanks a lot!
I guess R12 needs to be adjusted as well?
As I see it, Q1 is a variable resistor and its resistance is set by the voltage reference with the aid of Q2.
Seems that Q12 is sort of feedback, set by the voltage divider R10/R11. Since Q12's emitter is on the same potential as the emittor of Q2, I think this controls the voltage drop over Q2 and thus the voltage fed to Q1.
Last I guess R12 and R6/R7 finetune the sensibility of the Q2/Q12 regulator.
Is any of this correct?
Have fun! Hannes
PS: and of course now there's the question wether a 7 V voltage reference that needs to amplified by additional 22% (when compared to the zener) still gives less noise.
High Octane phono preamp Wiki
Old 21st February 2007, 02:02 PM   #12
MRupp is offline MRupp  Germany
MRupp's Avatar
Without looking at the Pearl schematics, did you include an RC filter after the voltage reference? If not that would be more important than having the lowest noise figure from the reference itself.
Martin Rupp
Old 21st February 2007, 02:32 PM   #13
h_a's Avatar
Well, there's 3300uF attached in parallel and R=221 Ohm in series.
Cheers, Hannes
Old 21st February 2007, 10:20 PM   #14
MRupp's Avatar
Well, you have an R and a C closeby, but not the RC filter for the voltage reference!
Martin Rupp
Old 22nd February 2007, 12:43 PM   #15
h_a's Avatar
Well after reading Ron Mancini's article on that topic, one could insert an 50 Ohms resistor in series. However this affects the regulator impedance? But probably not an issue here?
After some extensive searches/readings about that whole noise topic, the summary is terrific...no simple answer to the question what replacement for the zener gives less noise.
I think the lm329 would give less noise even if it has to be amplified by additional 30% (6.9 V vs. 9.1 V of the zener). Maybe connecting additional 50 Ohms in series would yield together with the 3300uF cap a nice RC-filter - but well this is just my impression. The cutoff-frequency of below 1 Hz is indeed impressive.
What about R9 (220 Ohm, connecting to the basis of Q2) then?
Remove it and use these 220 Ohm in series instead of the 50 Ohm?
Since I don't have any noise measurement equipment I cannot check wether all of this would really give some reasonable benefit.
I'm hoping somebody with more brain and experience could confirm my idea.
Cheers, Hannes
Pearl: replace zener D1 with voltage divider?Hide this!Advertise here!
Precision Voltage Divider - diy redrabbit Equipment & Tools 3 24th July 2008 04:16 PM
Voltage divider to reduce 6v dc to 2vdc duderduderini Tubes / Valves 5 26th February 2008 09:28 PM
Caps in Voltage divider Heater Bias ? Renron Tubes / Valves 1 4th December 2007 05:14 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 05:19 PM
replace a 5651 tube with a zener? jarthel Tubes / Valves 6 9th June 2006 01:43 AM
