My Aleph-X works!
My Aleph-X works!
Old 8th January 2003, 07:40 PM   #1
stefan is offline stefan
stefan's Avatar
Send a message via ICQ to stefan
Default My Aleph-X works!
I used last holidays to make prototype of Aleph-X.
So now it's ready and works!
What i did and what I have in result:
I use schematics xa1build.zip from rtirion posted in Alepx-X thread with some modifications:
1. Matched pairs of 0.2 ohm resistors
2. Matched pairs IRF9610 in 10 mV.
3. Matched pairs IRFP044 with less than 10mV each.
4. R8 is 10k resistor + trimmer 200k.
5. Current source is with TL431 and one bipolar transistor (like described in TL431 datasheet) with trimmer 200ohm to adjust current. (I have a lot of TL431)
6. 300VA transformer 2 X 14 V secondary (may be for halogen lamp), bridge with 2 X 22mF capacitors on each rail (total 4 capacitors).
Results:
1. 8 mV output offset which is stable in the time. This offset can be compensated ot 0.0 mV with 200k trimmer, but one side was set to 1.9 A and other to 2.5 A. I return to both equal currents and again
have 8 mV DC offset on output.
2. No power on pulse in speakers, power off also don't exists.
3. Pulsations on power rails were about 1V. On output were very little hum audible from less than about 0.5 meters in front of the speaker.
4. I put coils from old power supply filter (1 mH, 4A) with common iron core and ripple on the rails lowered to 0.3 V. When cross pins on one coil ripple drops to less than 100 mV peak to peak! In this configuration (TR-BRIDGE-C-L-C) with these coils (1mH) and capacitors (2 X 22mF) there was no audible hum on speakers (input was open)!
5. Rail voltage now (with C-L-C) is 14V.
6. With modified Aleph-P preamplifier sound is excellent! Power is enough and bass is very controlled!
This was only prototype of one channel.
Now I'm making some PCB layout and will post here
results when build 2 channels.
Here is the schematics of front end current source:
Old 8th January 2003, 09:05 PM   #2
rtirion is offline rtirion
Congratulations. And start enjoying music like never before.
Did you make a PCB or did the hardcore(wire) thingie?
regards.
Old 8th January 2003, 09:16 PM   #3
stefan's Avatar
I use PCB for prototypes with 5mm squares.
Now I'm making "real" PCB and I'll post here some pictures.
Old 8th January 2003, 10:23 PM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Yes my precious! Pics!!
Old 9th January 2003, 07:07 PM   #5
Taco is offline Taco  Netherlands
Very nice, you' are the first in Bulgaria with an Aleph-X
Old 18th December 2003, 09:40 AM   #6
stefan's Avatar
Talking I think there must be a pictures!
I enjoy my Aleph-X more than 6 months up and running excellent!
Here is a picture of my Aleph-X monoblock.
Thanks again Nelson!
Old 18th December 2003, 09:44 AM   #7
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Very nice amp Stefan!
Well done!
Bouke
More Power Igor! More Power!
Old 20th December 2003, 08:47 PM   #8
promitheus is offline promitheus  Europe
promitheus's Avatar
Very nice finish to the amp.
Those heatsink look cool.
Really good work you did there.
I guess you have a lot of fun listening to music.
My Aleph-X works!Hide this!Advertise here!
Anyone know of GC that works from +/-50v Stuart Easson Chip Amps 21 29th November 2006 06:28 PM
New mini Aleph works! But Q's ???? chipco3434 Pass Labs 3 8th December 2005 04:35 PM
It works .... jcayer Pass Labs 3 28th February 2005 02:00 AM
my new amp works, but... hugobross Solid State 3 28th October 2002 04:43 PM
