Anyone tried to place the volume control at input rather than original design at output stage? Sound any difference and trade off?
#2 |
This has been discuss quite a bit. Nelson has said the volume control can be either before or after his premaps, but after is better.
Do a search for attenuators or BOSOZ volume controls. -David |
#3 |
This is one of those things you can talk about endlessly, but trying it both ways will tell you what you want to know.
If you have a fixed, unchanging, front end, the impedance presented to the input device will be more-or-less known. The pot at the back will not only reduce the signal, but the noise as well. On the other hand, the circuit may be more sensitive to overload. Putting a pot at the front allows you to trim a hot signal, but whatever noise the circuit generates will always be there, even if there's no signal. Grey |
#4 |
> The pot at the back will not only reduce the signal, but the noise as well. ......
All true, and I can confirm that from my own experience. The disadvantage of a pot at the back is : 1) Your preamp has to swing a long more voltage than the other alternative. Not a problem for Aleph P, but certainly not true for all other preamp circuit. 2) If you have low impedance load (say 100-200 ohms) at the output, then you need thermally stable, high-power resistors in your attenuator of probably quite low values. Otherwise I am all for pot at the back. Patrick |
| volume and aleph 1.7 | Kongen | Pass Labs | 2 | 9th April 2006 12:45 AM |
| Aleph P1.7 volume control | supernet | Pass Labs | 3 | 23rd September 2004 06:30 PM |
| Aleph-X volume | Prune | Pass Labs | 39 | 15th March 2004 06:05 AM |
| Aleph P1.7 Volume Control | jleaman | Pass Labs | 7 | 18th September 2002 02:13 PM |
| Aleph L volume control | diy student | Pass Labs | 2 | 31st August 2001 06:03 PM |
| Page generated in 0.08378 seconds (67.16% PHP - 32.84% MySQL) with 10 queries |
