I have built Aleph 5 before 6 months and it works fine. But i notice that one heatsink heats a litle bit more than the other so I measure voltage accros source resistors and all vlotages are around 0.6 and 0.65V but on one source res. is 0.8 V. So what could be the problem mosfet Off-toleranc of source resistor or something else?
Sorry obout my bad english. |
#2 |
if it´s just one than probably the fet wasn´t matched good enough. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
Could it be off tolerance of source resistor rather than the unmatched irfp240. Thats the first thing that came on my mind?
#4 |
That would indicate a resistance value about 33% off. Unlikely, but possible. You can actually measure this in-circuit.
Indeed, a FET which has it's channel "opened wider" (!?) due to unmatched gate characteristics is much more likely, as just a little deviation from the rest of it's bank would make this FET conduct more of the total current than each of the other FETs in this bank. We're talking 33% here... Cheers. |
#5 |
On R42
#6 |
ok thank for the advice FET is going out.
| Aleph-x hot source resistor | globalweb | Pass Labs | 6 | 19th July 2007 02:26 PM |
| Resistor source? | jaymanaa | Parts | 2 | 24th June 2006 02:13 PM |
| Source for 22K Resistor in Brian GT Amp | kestrel200 | Chip Amps | 4 | 19th September 2005 08:19 PM |
| Why source resistor?i understand it | Mordor | Solid State | 27 | 27th June 2004 10:47 PM |
| Page generated in 0.07620 seconds (73.03% PHP - 26.97% MySQL) with 10 queries |
